Question about HP DeskJet F4280 All In One Printer InkJet
How do I get my deskjet F4283 to accept a refilled cartridge?
    Problem Solver:
  • 15 Answers
You just need to re-install the cartridge as if it was a new one.
The printer should treat it as if it was a new cartiridge and reset ink levels in the system.
Posted on Aug 06, 2009
My HPDeskjet says alignment failed. Cartridges are set to default quality. I just replaced the ink cartridge.
Are they refills? HP will not accept refills at all . I know from experience.
If they are HP cartridges then the print head is probably clogged. ( the big square tray that the cartridges fit into)
You'll have to remove it (just a latch or clip. Look in manual) and replace it. They can't be cleaned. I've tried on several different models.
Jul 14, 2016 | HP Deskjet 3050A e-All-in-One -...
Hi. we have HP DESKJET F380 ALL IN ONE Printer-Scanner-Copier. but suddenly we cant refill the cartridge and we can't print any documents cause its always have error and we dont know what to do. also in...
I had this problem. My HP F380 also stopped accepting professionally filled cartridges too. The only solution was to start buying HP cartridges. Thankfully these are much cheaper on eBay than buying at the RRP in shops or elsewhere online.
Jan 19, 2011 | HP DeskJet F380 All-In-One Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
After refilling my Original HP 818 Cartridge....the printer is not accepting it (considering it as a blank/Incompaible cartridge). How can I use refilled cartridge in my Printer( HP D1668)
hi
try cleaning th contacts of the black cartridge and the contacts of the black cartridge carrier with a wet towel
if that is not working you need to replace black cartridge because the printhead of your cartridge has been overheat due air left in tha cartridge
check here the right way for refilling
http://www.youtube.com/watch?v=dhDaKSzou50
May 03, 2010 | HP DeskJet F380 All-In-One Printer
I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Dec 30, 2009 | HP Office Equipment & Supplies
818 cartridge refilling
If you mean the HP DeskJet F380 cartridges (the HP 21 and HP 22 cartridges) you will have unreliable success refilling these cartridges either yourself or online, at Costco, Office Max, and Walgreens. These refillers generally don't have fantastic quality control or knowledge of printer cartridges. I suggest Cartridge World or Office Depot refills. If you mean the HP Photosmart C8180 (the HP 02 cartridges) refilling them is easy but you need to replace the chip on the cartridge for it to work in your printer. As long as a refilled cartridge has a new chip it should work in your machine. Again I recommend Cartridge World or Office Depot refills.
Nov 24, 2009 | HP DeskJet F380 All-In-One Printer
After refilling my hp deskjet f4185 cart it gives error message why so
Try putting in a DIFFERENT cartridge first then back to the refilled one.
HP tried forcing one to install new by imbedding a serial number in the cartridge read by the printer. Once you temporarily change to a different serial number it will accept the old again.
Oct 10, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
How do i make printer accept refilled cartridge t
Maybe you did not refill and insert it very well.
follow this steps in refilling your ink
1. remove the ink cartridge from the printer
2. make a hole at the top end of the cartridge, the hole can be made under the label on the cartridge by using a sharp/hot pin.
3. if you are using a syringe and needle in refilling, make sure you did not insert it into the hole too much so that the cartridge does not get damaged in the process.
4. make sure the ink is not over-filled to avoid spillage which can cause a hell of damage on you printer as it does to my previous one.
5. Gently use the label or a masking tape to cover the hole and insert it into your printer.
Note: The printer gives a message that the cartridge is empty or non compatible, ignore the message and continue with your printing.
It is also advisable that you refill your cartridge not more than 2 times.
If this solution does not help you, contact me on holamydes@gmail.com for more assistance.
Aug 15, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP Deskjet D1460 (Ink level problem)
Hi
They key to successful refills is to remove air bubbles from cartridges check here the right way
Jun 16, 2009 | HP DeskJet D1460 InkJet Printer
HP DeskJet F4280 All In One Printer InkJet Logo
670 people viewed this question
Seeker5211
Seeker5211
