Question about Olevia LT32HVE 32 in. LCD Television
BLUE SCREEN only when power is turned on
I only get a BLUE screen When I power up the television. I only use it for TV and nothing else. How do I get it back to the Normal mode for watching TV?
  • 1 more comment
  • engteach67 Sep 08, 2008
    Although we only use the TV for a few hours, we often get the "No Signal" blue screen. NOTHINg seems to help---since I cannot access any menu choices (they can't be seen). I've called Olevia a number of times; the only "answer" I have gotten is "turn off the TV for 6 -12 hours. Doesn't make sense to me....and my TV is less than 6 months old!
    I did go through the DISH TV network that we have; their technician says everything on this side is AOK.
    Now what??
  • greenburg4 Mar 02, 2009
    I have the same problem but mine is a 42", did you find a fix?
  • Anonymous Mar 15, 2014
    I want to watch television but it says "no sync" and I have been through every option on the menu and can not get the tv to work. I have used the same cable to hook up to another TV and it works fine, so it is not the cable box or the cable wire. Before I reached the final setup on the gym and when i first got the bike I quickly put the cable in to see if it works and was able to get the tv on the screen. Now, which is about a month since i initially tested the bike, I can't get it back.
How do I set up and program my olevia hd tv. bought without manual
Posted on Mar 03, 2008
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3 > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
Jan 28, 2016 | Televison & Video
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
When I turn the TV on it goes to the blue screen but nothing works then the TV powers off on its own.
Blue screen usually indicates no input. Check the input selection. Check the cables from the source. If everything is correct, try this: unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and try again.
Apr 18, 2011 | Mitsubishi LT-52153 LCD TV
Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
Dec 09, 2010 | Vizio Televison & Video
Toshiba Flat Screen Problem
Is there a switch on the side of the remote? If there is make sure it is switched to TV. If there is not, try removing the batteries from the remote for 5-10 minutes. It should revert to the TV mode. Thanks for using fixya.
Nov 06, 2009 | Televison & Video
Polaroid tv w/ black screen
hi..then there is a problem in your smps
power supply.If you have the warrenty period
take it immediately.
check it out..
thank u..
rate me..
Feb 28, 2009 | Polaroid FLM-3732 Television
Blue screen on the power up of LCD Sony bravia kdl26m3000
A blue screen usually indicates that you are on an input with nothing hooked up to that input.
Feb 22, 2009 | Sony BRAVIA KDL-26N4000 26 in. HDTV LCD TV
Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Nov 20, 2008 | LG 32LB9D TV
Tv shows blue screen
my tv screen is blue and has a red key at the bottom left hand corner
Oct 04, 2008 | Apex Digital AT2002S 20" TV
Olevia LT32HVE 32 in. LCD Television Logo
328 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
