Question about Epson Office Equipment & Supplies
I have an epson model EMP-S5 when I power it up the power light starts green goes to red and the bulb light flashes. I tried holding down the left, right and enter button powered it up and while holding those buttons attempted to push the on button and nothing happened. I let go of the 3 buttons turn it on and same thing occurs. Bought anew bulb and installed made no difference.
Epson EMP-S5 not displayed when connected to my PC and Laptop!
what should im doing?
Posted on Jan 02, 2010
My epson emp-74 won't show...the red light keeps on flashing
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Dec 06, 2012 | Epson (V13H010L32) Projector Lamp for...
How to reset lamp after replacing the lamp on epson emp x5
1. Make sure, your projector is on standby.
2. While holding down the projector's Comp Sync + and Comp Tracking + buttons, press and hold down the power button.
3. After status light 1, 2, and 3 flash ON and OFF at least three times, release the Comp Sync + and the power button. The flashing lamps status indicate that the lamptimer is reset.
Aug 02, 2011 | Epson EMP-X5 LCD Projector
Epson EMPS5 lamp light is blinking. Do we need a new lamp?
THIS MAY NOT BE A BULB PROBLEN THIS MAYBE A SINCER PROBLEM A TRANSISTOR PROBLEM CAUSING THE MACHINE TO NOT WORK PROPERLY
IF THE LIGHT FLASH AND HOW MANY TIMES DOES IT FLASH AND WHAT COLOR IS THE FLASH.
GO ON LINE
EPSON EMP-S5 PROJECTOR 5 FLASHING YELLOW LIGHT
ENTER
SEE IF ANYONE ELSE IS HAVING THE SAME PROBLEM AND WAS IT FEESABLE TO FIX IT OR RESOLVE THE PROBLEMS
ROD
Feb 10, 2009 | Epson EMP-S5 Projector
My epson emp-50, gets off after ev.5 mins. says NO SIGNALS. but audio comes....pl.help
check for the error indicator in the projector, if the bulb light is flashing red, then i think you need to clean the units ventilation fan, if cleaning doesnt solve the problem, you have to replace the bulb.
Jan 29, 2009 | Epson (V13H010L13) Projector Lamp for...
EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Jan 11, 2009 | Televison & Video
Warning lights
Just so you know guys (and this procedure is not for the faint hearted!). I had the slow one second red warning light flash. I checked the bulb, which was find and I left it powered off for 48 hours. My projector is no longer under warranty and would have cost me over £300 to have it looked at. I ventured inside to inspect the boards, once I removed the main board to check the power supply I heard movement from one of the light ducts. It took me a while to removed enough to discover the fixing screw which holds the imaging cube in place (which is between the 3 light ducts and the projector lens) had come out (!?) and was rolling around inside the unit. This would also explain why sometimes I could not focus my unit properly. I remounted the imaging cube, put the whole thing back together and PRESTO! My projector is working again.
lee.read@gamil.com
Jun 21, 2008 | Epson EMP 720 Multimedia Projector
Epson EMP-74 - Blinking Red Light
Hi Sootycat
Ok , most of the time this would be the Fan.Powerboard that is faulty then and unfortunatelly it would be better to replace the part rather than having it repaired.
Repaired Powerboards normally give the same problem a couple of months down the line.
Apr 15, 2008 | Epson EMP-54 Multimedia Projector
Epson Multi-media Pojector, Model:EMP-S1H
please reset lamp hrs to zero... and clean its air filter located in bottom side.
Mar 17, 2008 | Epson EMP-S1H Multimedia Projector
Epson emp s1
hi,
Pls check the lamp condition.
Viren
Jan 18, 2008 | Epson EMP S1 Multimedia Projector
Projector problem - Epson EMP-S1H Multimedia Projector,
try to reset lamp by using menu, up, down and enter buttons. also reset the filter and try again.
Viren
Nov 24, 2007 | Epson EMP-S1H Multimedia Projector
404 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
