My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
    President:
  • 1,776 Answers
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Posted on Aug 02, 2009
My clothes are being stained but not brown or black marks and its not every wash
Posted on Oct 06, 2011
My Frigidaire FTF530FS Front Load Washer appears to be leaking oil and it is getting on my clothes
Hello Loree Grudem - This can be the result of the shaft bearing and seal. They may have become worn and the transmission oil is creeping up to get in your water. Once this happens, it gets on your clothes to cause staining. Or possibly you have a buildup of fabric softener that comes loose and puts a greasy like substance in your water and on your clothing. Once you put your clothes in the dryer and the old fabric softener melts you will see these spots. I suggest contacting a professional to move forward accurately.
Oct 09, 2012 | Frigidaire FTF530FS Front Load Washer
My dryer is leaving brown stains on my clothes. I think that the drum needs to be aligned. Is this an easy task?
If your dryer is leaving small brown streaks on your clothes, then your drum seals need to be replaced. It is not a hard task if you know what youre doing. It is a complicated one for a beginner because you have to take your whole dryer apart to replace the seals
Jul 13, 2011 | Dryers
Brown stains in the drum of my whirlpool dryer
Apparently a common problem with 4-5 year old Kenmore and Whirlpool dryers. The paint is rubbed off the back panel by the felt seal attached to the rotating drum. The bare metal gets rusty from the damp clothes. The rust is rubbed off by the felt seal. The entire felt seal will turn brown. The stains are transfered to the clothes. The rust stains can generally be removed by additional cleaning.
I'm going to replace the felt seal on the drum, clean the rust off the back panel and see how long it lasts. Seal w/ adhesive is $30-40.
Some have suggested painting the back panel, but i don't think fresh paint is going to last long. The original paint was probably electrostatically applied and maybe baked on.
Nov 05, 2009 | Dryers
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore 44102 Front Load Washer
The clothes get stained with brown burn marks while in the dryer.
The rear drum support needs replacing.
The front glides and felt seal needs replacing.
May 25, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Kenmore dryer
ck rear (or front if it has one)drum seals they tend to develop rust stains over time the rust comes off on clothes leaving brown streaks ..seals will need to be replaced although you may try a bleach and water solution first drum will need to be removed to replace seals
Nov 03, 2008 | Kenmore Dryers
My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine. my washing machine is lessthen three years old and always give brown stains in white...
I had the same problem, and it turns out that it is NOT the seal. It is the liquid fabric softener. The fabric softener dispenser needs to be cleaned periodically or it gets a black waxy, goopy, build up. It is this same buildup that ends up staining your clothes with dark brown or black stains. Just remove the dispenser and wash it our very well and the problem will be gone.
Oct 25, 2008 | Washing Machines
Dryer leaves pinkish-brown residue stains/streaks on white clothes
The cause of these stains is worn seals. Over the course of time debris & chemical residues left from the wash process are deposited into the drum seals. The continual heat applied to these residues causes a reaction which turns the seals a reddish brown in most cases. The time this takes varies with the amount of laundry done. Clothing is then brought into contact as they tumble in the dryer. To remedy the problem you will have to replace the seals on the drum.
Each manufacturer has different designs so what is involved is determinant on the manufacturer. The most common domestic manufacturers are Whirlpool, GE, Frigidaire. Most of the brand names seen in stores are derivatives of these. This includes Maytag. It was purchased by Whirlpool in 2006 who has been incorporating their design into Maytag since. Only the Maytags since 2006 have the Whirlpool design. In 2006 they were still selling the old Maytag stock while retooling to manufacture the Whirpool design so you have to tread carefully when determing what you have if purchased in 2006 & possibly into early 2007.
Whirlpool--Some other derivatives--Roper, Kitchenaid, Estate, Kenmore.
Frigidaire--Westinghouse, White-Westinghouse, Gibson, Kelvinator, Tappan, Magic Chef, Electrolux
GE--Hotpoint. GE also manufactrurs some appliances by using off-the-shelf designs. As an example some of their dryers use a GE--Frigidaire derivative.
This is not meant to be a comprehensive list. It is also not meant to say they are all equal as long as you buy any brand from that particular manufacturer. The reason for having so many different brands is that while you incorporate some basics of design similarity you can also add or subtract features to have a particular brand serve a niche in the marketing scheme.
Feb 20, 2008 | Dryers
Washing Machines Logo
746 people viewed this question
Top Washing Machines Experts
