Question about Dell V305w All-In-One R840635AU InkJet Printer
Install won't accept my WEP key. 3 extra random
Install won't accept my WEP key. 3 extra random characters keep getting added
  • 630 Answers
WEP keys must be 5, 13, 16 or 29 characters long.
Posted on Aug 22, 2009
I am trying to get on the wii internet like i always could but it loads for 30 sec. to 1 minute. the it says error code: 51332
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
If your router is using WEP encryption
  • Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
If your router is using WPA encryption, the Wii is compatible with :
  • WPA - PSK(TKIP)
  • WPA - PSK(AES)
  • WPA2 - PSK(AES)
If your router is using MAC filtering, ensure the Wii MAC address has been added to the list of approved MAC address on your wireless router settings.
Jul 28, 2011 | Nintendo Wii Console
Would like to change my wep number
Welcome to FixYa! A WEP key is a security code used on some Wi-Fi networks. WEP keys allow a group of devices on a local network (such as a home network) to exchange encoded messages with each other while hiding the contents of the messages from easy viewing by outsiders. For you to be able to change the WEP key, please follow the instructions below.
1. Open up a browser.
2. Type 192.168.1.1
3. Type admin as the username and admin as the password ( if admin is not accepted as the password,try to use password as the password )
4. Click on Wireless Connection Tab.
5. Click on Basic Wireless Security Settings.
6. Scroll don on the page and you will see there the WEP key option.
7. Type your preferred WEP key which consist of 10 characters, 0-9 and A-F only.
8. Click Save Settings.
Hope this information will help. Thank you for using FixYa!
Sep 22, 2010 | Westell Wirespeed VersaLink...
Not able to connect the sons Nitendo DSi to the internet. They are asking for the WEP Key but on my home hub there is only a WPA Key. BT have told me to connect to you to ask for support.
If your using WPA and your Nintendo DS only supports WEP Encryption theres no way you can connect it to the internet. WEP encryption is different from WPA.
WEP key uses hexadecimal - using characters 0-9, A-F or ASCII format. The ASCII format is easier to remember. The ASCII string is converted to HEX over the network.
Example of WEP key encryption are:
*64-bit hexadecimal keys are exactly 10 characters in length. (12345678FA is a valid string of 10 characters for 64-bit encryption.)
*128-bit hexadecimal keys are exactly 26 characters in length. (456FBCDF123400122225271730 is a valid string of 26 characters for 128-bit encryption.)
*64-bit ASCII keys are exactly 5 characters in length (DMODE is a valid string of 5 characters for 64-bit encryption.)
*128-bit ASCII keys are exactly 13 characters in length (2002HALOSWIN1 is a valid string of 13 characters for 128-bit encryption.)
WPA Key is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
To resolved the issue you have an option to change the WirelessSettings on your router to WEP instead of WPA since WEP is also a secured netwrok. however you need to keep in mind that if you change the encryption you need to configure all othere device connected to the router via WPA and change the settings to WEP.
Thanks for using Fixya
Aug 02, 2010 | Computers & Internet
Are trying to enter the WEP key and it is not allowing any more the 5 characters (please input 64 bit WEP encryption and Five ASCII Characters))
It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption.
Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead.
Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1).
Click here if you cannot access the web-based configuration.
Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen.
Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key.
Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption.
  • 64-bit encryption 10 characters
  • 128-bit encryption 26 characters
  • 256-bit encryption 58 characters (available on DI-614+ only)
    The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key).
    Step 5 Click on the Apply button then click on the Continue button to save your settings.
  • Jun 25, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
    Connection error code 51301
    google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);This error is caused by issues with the WEP Key of your wirless network.
    To solve this error :
    • * Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
    • * 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
    • * 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
    If your router is using MAC filtering, ensure the DS MAC address has been added to the list of approved MAC address on your wireless router settings
    Set your router settings to "mixed" or "b and g" mode when using connection files 1,2, or 3 .
    May 01, 2010 | Nintendo DS Lite
    My ps3 does not accept my wep key. Complains that it has to be 10 or 26 characters. I know it is the correct key
    Ok, hi. I had the tue same problem but i think i figured the problem out. My ps3 used to connect no problem to my home wifi but now it wont conmect anymore because it wont accept my WEP key. After i read the little thing that says its wrong i realised it had to be 10 OR 26 characters exactly one of those two numbers. I hope i helped.
    Dec 03, 2009 | Sony Playstation 3 (PS3) Console
    Can't connect the artisan 800 to our wireless network
    To add the printer to your wireless network, you need to know the name (SSID)
    of your wireless network. If it has security enabled, you also need to know the
    WEP key or passphrase. Write down the SSID and WEP key or passphrase below:
    ■ Network name (SSID): _________________________________________
    ■ WEP key or passphrase: _________________________________________
    Note:
    If the WEP key is either 5 or 13 characters, it’s ASCII. If the WEP key is either 10 or 26
    characters, it’s hexadecimal. The default WEP key is usually 1.
    If your passphrase contains upper- or lowercase letters, be sure to note it correctly.
    The printer supports the following wireless security modes: WEP 64, WEP 128, and
    WPA-PSK.
    If you don’t know your wireless network name (SSID) or WEP key or passphrase,
    contact the person who set up your wireless network before you begin.
    Insert the printer software CD.
    2. Windows Vista®: If you see the AutoPlay window, click Run Epsetup.exe.
    When you see the User Account Control screen, click Continue.
    Windows® XP: When you see the Software installation screen, continue with
    step 3.
    Mac OS® X: Double-click the icon.
    3. Click Install.
    1.Make sure that the printer is turned on.
    2. When you see the FireWall Warning screen, click Next.
    3.Make sure you connected the Ethernet cable
    Oct 09, 2009 | Epson Artisan 800 All-In-One InkJet...
    Psp not accepting wep key
    You need to choose the correct security setting before you enter the WEP key where it asks you if its WEP. ASCII or unencrypted choose the correct one!
    Feb 05, 2009 | Sony PlayStation Portable (PSP) Console
    WEP Encryption
    It is recommended to enable encryption on your wireless router before your wireless network adapters. Please establish wireless connectivity before enabling encryption. Note: Your network will slow down and wireless signal may degrade when enabling encryption due to the added overhead. Step 1 Log into the web configuration of the router by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 Enter your username (admin) and your password (blank by default). Click OK . Click the Home tab and click the Wireless button on the left hand side of the screen. Step 3 Select Enable next to the WEP radio buttons. For WEP encryption select 64, 128, or 256-bit encryption. For the Key type select HEX. If you have an option for Authentication type, select Shared Key. Step 4 Select Key 1. Enter a Hex encryption key that you make up. The length of the encryption key will depend on what you selected under WEP Encryption. 64-bit encryption 10 characters 128-bit encryption 26 characters 256-bit encryption 58 characters (available on DI-614+ only) The encryption key is HEX, meaning 0-9 and A-F are valid characters. For example, A4583DFF1A (64-bit HEX key). Step 5 Click on the Apply button then click on the Continue button to save your settings. Note: If using non-D-Link adapters, please refer to the manufacturer´s documentation on enabling encryption.
    Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
    WEP Encryption
    Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
    Dell V305w All-In-One R840635AU InkJet Printer Logo
    127 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
