My first thought was that it was a problem with the drive belt or tensioner, but if it spins, that can't be the answer. That points to a main board or motor controller problem. In the first instance try a Power Reset. Disconnect the machine from mains power for a couple of hours, or preferably overnight. Press and hold the power button for 30 seconds and then plug it back in. If that doesn't fix it, you need a service call. It doesn't appear to be a known issue.
This error can't be reset, it is a repair job. The code mostly means that the carbon brushes are end of life. You can replace them yourselves with new spare parts. Mar 22, 2018
Please don't type all in capitals. It is hard to read and considered 'SHOUTING'.
Hi, (Englishman actually in France and understanding most of written French!!)
You need to type into your search machine ' siemens washer manual' and you should be presented with sources from which you can either download for free or pay for a manual. The sites will ask for the model number at some point!
Thanks for using FixYa. Error IE water inlet error which occurs when correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes. Please do rate the solution if the issue is resolved or post a comment for further assistance.
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Error ld means Long drain. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
If it doesn't clear the error then check whether your drain is kinked or clogged with lint and debris. If not then there is definetly some problem with your drain filter and/or drain pump.
Please do rate the solution as FixYa and Revert for further assistance.
