Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
{View the site in web view by Mobile or a desktop to see the search box. Mobile view has no search box.}
SOURCE: Universal Remote not working
With nearly all brands of universal remote control, there is usually more than one code for Philips. Keep going through the codes until you find one that works correctly.
So if you know that the 1st code doesn't work, then don't save it, and move to the next.
You may find that several codes will actually put the TV into standby, but other functions will be different.
SOURCE: Jensen Universal Remote
HOLA NECESITO SABER COMO SE PROGRAMA EL CONTROL REMOTO UNIVERSAL JER 422 Y SU CODIGOS PARA PROGRAMAR TV DEAWOOD, SONY Y SAMSUM
ATTE.
GERARDO
SOURCE: Universal Remote Control
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately,
Coby is a company whose electronics cannot be controlled by any remote
other than the one that came with it. This means there is no code
available for universal remotes. If you need a replacement remote (it
will be identical to the one that came with the unit) please call our
customer service number above. They will take your information and
provide you with the procedure for ordering a part from Coby.
If
you feel this solution doesn't deserve a good rating, please let me
know why so that I may better assist you. If there is anything more I
can do to help, I will!
SOURCE: Trutech Tv/DVD combo ...need code to work with universal remote
go to mr.remotes.com and look for tv type and look for your tv's code {on back of tv} and you can buy a new one
SOURCE: Universal Remote code for Insignia Blu-ray dvd player NS-2BRDVD
Insignia says it will not work with a universal remote there is no code.
