Whirlpool Washer Dryer 1000 (997) - minor leak from under the washing machine. What is most likely causing this? And... where can I find a manual online for this machine? Many thanks, Steve
  • Washing Mach... Master
  • 1,606 Answers
Waterpump most likely leaking . http://www.servicematters.com should show you a technical manual online . Don't know if it will show how to disassemble or not though .
Posted on Aug 02, 2009
Whirlpool duet front loader washer has a water leak from under the machine. What could be causing this?
Pull off the lower front panel and watch while washing . You should be able to pinpoint it .
Mar 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I hate my Whirlpool Cabrio washer- I've had it for almost 4 yrs- digital display board broke at 2 1/2 years and cost $450 to repair. Now I have leak under the washer who knows how much it will be to...
I also hate hate hate my Cabrio washer and dryer. I've been a loyal whirlpool customer for over 25 years with ALL my household big appliances. ThWhirlpool doesn't care about loyalty. I bought this washer and dryer set in Sept. 2010. The clothes don't get clean....the darks have white streaks on them. I have to re-wash about every other load. I washed a pair of jeans and they still had dirt on them when I pulled them out. I called Whirlpool and their response was "What do you want me to do about it?" They said they can't do anything bc the washer is an energy saver.. I will NEVER buy another Whirlpool appliance.
Sep 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
During the wash cycle of the 24" combo washer dryer, it leaked
A hose inside the washer is your most likely culprit. On older whirlpool washers they used a plastic hose to run from the pump to the back case of the machine that was pretty susceptible to cracking.
Jun 28, 2010 | Whirlpool LTE6234D Top Load Stacked...
Puddle under 1 yr old washing machine hours after it is finished
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
May 19, 2009 | Kenmore 22422 Top Load Washer
Whirlpool duet gas dryer GGW9200L need error codes and proceedure to enter test mode
There is a mini manual located inside of the machine whith the codes and troubleshooting guide on some they are on left and some are under the top.
Mar 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water Collection in Washer when Machine is OFF
you may have something lodged in the pump, pumps easily removed worth checking
Nov 17, 2008 | Whirlpool GHW9100L Front Load Washer
Washing Machine broke after power surge
First thing to check is mains filter. have replaced lots on this model!! This is located where the cable comes into the machine.Usually obvious visually if burnt.
Nov 11, 2008 | Smeg WD16BA Front Load Washer / Dryer
Washer off balance
Check your skate plate assembly or Base pad. these are the leading reason why the machine will be jumping around.
If these are in tack.
Please specify minor repair.
Feb 11, 2007 | Whirlpool GSW9800PW Washer
Washing Machines Logo
233 people viewed this question
Top Washing Machines Experts
