Display is flipped 90 degrees unless startup is done in safe mode
  • 2,200 Answers
Hi
Hi some graphics cards such as ATI have an option to rotate the display through 90 degrees.
Either from your system tray, or from Control Panel, get access to the Graphics Control Panel.
One of the options will be for 'Rotate Display' - just turn your display back through the 90' arc that it has moved through already and this should resolve the problem.
Some actions known to correct the problem depending on your graphics card are;
1) RIGHT CLICK in Desktop area - select properties/settings/advanced. look through the tabs for one that contains rotation settings.
2) Using your keyboard - try these
Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
(If that doesn’t work, try Ctrl-Shift-R)
If you continue to have difficulties please post up details of your graphics card and OS and I will continue to troubleshoot the problem.
Many Thanks. If the problem is resolved please accept and rate my answer.
Posted on Aug 02, 2009
PICTURE FLIPPED 90 DEGREES
if u are using windows 7 the right click on desktop click resolution then rotate your display.
Dec 07, 2013 | HP Computers & Internet
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
My screen does not flip 180 degrees when i turn the screen around
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
Acer tablet troubleshooting
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
P c screen upsidedown
Hope this helps
Oct 20, 2012 | Fujitsu Siemens ESPRIMO MOBILE V5535...
Display flipped vertical
Hi, i'm not 100% on yours, but this may well lead you in the right direction, if you right click on your desktop, a menu will pop up, select personalize, then select - display settings and do it in there.
I have nvidia control panel and i can do it in there.
There may be a short cut key, if someone else reading this might like to clarify.
Try -
ctrl - alt and arrow key to turn 90 degrees
I hope this has helped you, if you need more help please ask.
Jan 30, 2010 | Acer Aspire One PC Notebook
Rotation of desktop
Flipped monitor display in Windows. Third-party software utilities such as the NVIDIA Settings have the ability to flip or rotate a monitor's display 0, 90, 180, and/or 270 degrees
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
