Question about Frigidaire FAS255J2 Air Conditioner
We live in a non studded home, can the walls support a 24,000 btu aircondition with support outside on the wall only?
  • lj11792 Aug 02, 2009
    Windows are not made for air conditioners they open to the side. The home is called a plank home.
  • 227 Answers
What are the walls made of? Some details there would better help us t advise you on what to do. Also, this being a window unit, why not just mount it in the window?
Posted on Aug 02, 2009
  • Michael Beverlin Aug 02, 2009
    Sorry if I posted a solution. i meant to post as a clarification. After doing some research, Plank homes are made of many different materials. This being said, knowing the composition of the exterior wall is a must. And I was unaware of the side opening windows let me apologize for that also. But like I said, if you can give me idea of what materials we are working with, maybe I can offer a solution to your problem.
Problem with Fujitsu minisplit heating
did you try to set to maximum heat? (suspect the thermostat is defective)
Oct 03, 2015 | Fujitsu AOU24RLXFZ Dual, Tri and Quad Zone...
How is drywall properly installed in a home, the walls and ceilings in kitchens living rooms and bedrooms? Is it just nailed to the studs or does it have to have back on board behind it? But as backerboard...
First, insulation is put in on exterior walls with specific R ratings, drywall is just screwed to studs then spackled.in bathrooms it's a little different. There's different options for material backboard that are waterproof. Some are fiberglass then are finished in resin sealant
Feb 22, 2015 | Drywall
I am fixing a closet in my home. It is part of an exterior wall and creates a lot of coldness in the house. How can I insulate this wall better? My kid is freezing at night she says. <a href
If you have enough room behind the stud wall install 1" rigid foam tape seams and then use the thickest possible roxsul insulation to fill the studs. Or axe the foam and install 6mil plastic on warm side of the wall after insulating tape all seams when done.
Jan 30, 2015 | Cam Spray Pressure Washer Foamer...
What size ton a/c unit outside would be used on a 1500 s.q.foot ranch home.
Try to get 15 BTU's per square foot living space. 22,500 Btu, or go a little higher at 24,000 or 2 ton.
May 07, 2011 | Coleman Heating & Cooling
Whats the cooling capacity
1 ton of cooling equals 12,000 BTU
2 ton of cooling equals 24,000 BTU
3 ton of cooling equals 36,000 BTU
1000 sq ft home needs about 30,000 BTU of cooling..... if you live in Kansas USA.
This is basic cooling. Hope this helps.
Mar 26, 2011 | Heating & Cooling
Hi, I have a small Williams direct vent heater 14k btu that i want to install. for ideal placement, the double wall vent will be against the stud not centered. is this a problem? also can the existing...
The vent pipe CAN NOT touch the wall stud. You can cut back the fiberglass insulation, but it must be a minimum of 6" away from the vent pipe on all sides.
Jan 26, 2011 | Heating & Cooling
We built an outdoor room and the dryer vent is now "indoors".
you'll have to go to lowes or home depot and buy the rigid vent pipe not the flex type. Figure up the elbows and straight pcs. Usually vent pipe is 4,6,8 So make sure you get the correct size. Now as far as going through an existing interior since the vent pipe will be larger than the wall studs you want be able to go through the walls unless you have 6in. stud walls and the vent pipe for a dryer is usually 4in. I think. If you do have 6in interior walls you can run through them but make sure it's interior walls instead of outside wall interior walls usually dont have insulation. If you can't go through the walls your next option is simply through the each floor and out the roof or out the wall. Build a square chaise around the vent with 2x4 lumber, drywall and finish.Be careful if you go through the walls you may have to reroute wiring and water pipes.
Sep 07, 2009 | Samsung DV337 Electric Dryer
Only 1 speed
Verify that the fan capacitor is good. Verify correct voltage to the unit.
Aug 20, 2009 | GE Heating & Cooling
My wall is making a knocking noise
i'm thinking a pipe not a stud.... metal will expand more
Aug 20, 2009 | Heating & Cooling
Kenmore aircondition
First is to make sure the evap and condenser coils are very clean. A dirty evap coil will cause icing as well as a blower not running and low freon. Hope this helps. Thx RepairUSA
Aug 31, 2007 | Kenmore 75050 Wall/Window Air Conditioner
Frigidaire FAS255J2 Air Conditioner Logo
60 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
