Question about HTC Touch Diamond Smartphone
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I've checked all the settings - with ring and vibrate selected I only get vibrate, with any of the ring options without vibrate I get nothing except the flashing light. When I'm in the settings if I test the ringtone it plays perfectly, and alarm alerts also sound, so there is nothing wrong with the sound hardware.
I'm pretty sure the ring worked OK when I first got the phone. I went back to my old phone for a bit, and since re-installing the SIM card in the HTC, the ring hasn't worked.
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
Posted on Oct 17, 2009
My htc hd2 wont ring or vibrate even after i have did a factory reset
go to settings, then press the menu button so you go to all settings, tap sounds and notifications, then along the bottom tap notifications, then from the event drop down list select "phone: incoming call" and then on the ring type drop down list select "vibrate and ring"
that should do it ;.)
Oct 12, 2010 | HTC HD2 Smartphone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Vibration for text message
I use an HTC Touch. Hopefully the menu should be the same in Touch HD as per the Touch. Try this..
Start -> Settings -> in the Personal tab, click Notifications -> u might see 2 tabs -> select Notifications tab again -> select an Event (here it is incoming SMS) -> below you'll see the Vibrate option -> tick on it to enable it -> Select OK to save.
Hope this helps, If so, rate me.. thanks - billa..
Sep 06, 2009 | HTC Touch HD Smartphone
HTC Touch doesnt ring on incoming call
Hi. First thing, you can check your sound settings, by tapping Star Menu, then Settings, then Sounds & Notifications, and through that page, you can check if your incoming call alert is on (just sound, or vibrate and sound), you can try to change the ringtone to see if your current ringtone is damaged or not. (Since other sounds are alright, there shouldn't be any problem in your hardware or in the sound volume levels) Hope this helps.
Jun 14, 2009 | HTC Touch P3452 Smartphone
Accidentally dropped HTC diamond - Display blackout
zohail, i have similar prblem and would liek to give it a go myself. could you provode further instruction?
Thanks in advance
Alex
Jun 01, 2009 | HTC Touch Diamond Smartphone
Phone doesn't ring, but other sounds fine
:) Sometimes happens to me also. I faced a similar problem before, I think one of the installed programs on your device does it, I couldn't remember the name of the application now but whenever I launch it, my phone sound goes to minimum, Just to let you know. Have a nice day.
May 21, 2009 | HTC Touch Cellular Phone
You want to sell it? mail me at leon.tiger2@gmail.com
Apr 13, 2009 | HTC Touch Diamond Smartphone
HTC Touch HD - Vibrate function
The '********" is a little motor that spins with an offset weight. It sounds like the motor is stuck.
Feb 10, 2009 | HTC Touch Diamond Smartphone
Htc touch diamond vibrate problems
The instruction given in the user's guide are WRONG, which infuriated me. To perform a hard reset, hold down the power button and turn the phone off. Then, while holding volume down and the center button, turn the phone back on. It will give you the hard reset prompt immediately. Follow the instructions. I hope I saved you the stress I went through.
Dec 28, 2008 | HTC Touch Diamond Smartphone
Phone doesn't ring for an incoming call
try installing this Hotfix
http://www.htc.com/us/SupportDownload.aspx?p_id=88&cat=0&dl_id=101
Hot fix for resolving ring tone and system sound loss problem in HTC Touch Date: 2008-08-28     CategoryHotfix
In some cases, there may not be any ring tone and system sounds on the HTC Touch when the device has not been soft reset after a few weeks of usage. Performing a soft reset will resolve this problem. You can also download this hot fix and install it on your device to prevent this problem from reoccurring.
May 26, 2008 | HTC Touch P3450 Smartphone
HTC Touch Diamond Smartphone Logo
1,368 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
