Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Is there a reset button on the Badger 5 - Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
  • 22 Answers
Yes, on bottom a little recessed button should be pushed to reset the device. If the blade is stuck, the reset might not work but just keep tripping the breaker so you have to free up the blades with a broom stick or other item stuck into the disposal (with the power off of course) to turn the blades manually. Then try the reset button again. and hit the switch. Otherwise, check your kitchen's electrical breaker to see if it has tripped as well.
Posted on Aug 10, 2009
  • 14 Answers
SOURCE: does the badger 5 have a reset button?
Yes on the bottom.
Posted on Jan 28, 2010
SOURCE: there is no reset button
yes it is underneath. look, there.
Posted on Mar 20, 2010
heatman101
  • 43501 Answers
SOURCE: InSinkErator Badger 5, 1/2 HP Garbage Disposal: I have a Badger InSinkErator, it suddenly just sto...
Here is a tip the I wrote that may help you to figure out what is going on withyour garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Posted on Sep 23, 2010
heatman101
  • 43501 Answers
SOURCE: InSinkErator Badger 5, 1/2 HP Garbage Disposal: my disposal just humms not sure where the reset bu...
It is the redbutton on the bottom of the motor...
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: Water leaking out of bottom of unit, near reset
Here is a tip that I wrote about how and where a garbage disposal will leak and what can be done to fix it.
Garbage Disposal Leak from bottom of motor
heatman101
p
The badger 5 has just stoped working
There are three possible things.
1) Circuit breaker tripped
2) Wall switch gone bad
3) Reset button tripped on disposal
Reset is located near where wire connects to disposal
Nov 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 5+ quit. no sound no jam; got power to unit. 5 or 6 yrs. old. replace?
Did you reset the circuit breaker on the disposal? There should be a button on the bottom of the disposal unit.
Aug 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Our SinkErasor Badger 5 doesn't work.Wrenchette can't be rotated
MAKE SURE THERE'S NO STUFF INSIDE THE DISPOSAL. PUSH RED RESET BUTTON, (USUALLY UNDERNEATH OR ON SIDE) IF THERE IS ONE. THE DISPOSAL ALSO CAN BE TURNED USING A 1/4INCH ALLEN WRENCH. USUALLY INSERTED IN BOTTOM UNDERNEATH OF DISPOSAL.
Dec 15, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The motor on my Badger 5 disposal was humming but not rotating. I cleaned out all the debris, reset it and now there's nothing - no hum, nothing. Is my badger dead?
The badger 5 has a dislodge device on the bottom right in the very center. An allen wrench will fit if you have lost the tool that came with it.
FIrts you will need to dislodge anything preventing it from turning. (Insert the right size allen wrench and turn both directions) The remove whatever comes loose after dislodging.
Then opush the red reset button on the bottom. Check the breaker that powers up the disposal, as you may have tripped it.
If the breaker is on, the unit is turning freely, and the reset button is pushed, then the next step is to check for power using a volt meter, to make sure the disposal is indeed getting power. If all the above has been done, the unit IS getting power then yes, the disposal needs to be replaced.
Oct 11, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
1,198 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
