Printing a photo but not getting it upto your expectation.....?? No worries just fiddle a little bit with the printing options and keep in mind some important points that I am going to tell you....it will help:
1) RESOLUTION OF THE IMAGE TO BE PRINTED... Always keep in mind while printing a digital printout that the resolution should be best fitted i.e. of the original photo.... if you stretch A photo too much or squeeze you might not get the desired result. It depends upon the DPI i.e dots per inch that appear on the paper in the snap that you print. To get a quality print you must make sure to select proper dpi for an image in printing. Eg. for printing a snap of 300 dpi you must choose the image resolution as 600 dpi, but in case of professionally required image quality you can select upto 24oo dpi.
2) PRINTING PAPER ... Make sure that the paper you are using is suitable for the ink and the printer that you are using. Certain printers specially design Photo Paper suitable for the ink used in them for eg. HP printers do have Hp photo papers to give a good quality of image.
3) SETTINGS IN THE PRINTER... You can adjust the image quality that you want by clicking on the Properties Option in the printer dialog box that opens when you give a print command. for eg. you can select Economy mode for saving the ink (but this will not give a good quality image as colors to will be low), or you can use the Bes option, as suitable for you...
So next time you Print a photo or snap of yourself make sure to remember these points and have fun.....
Please follow these steps: 1. Turn your printer on. Most power buttons are located on the top of the printer. Press and hold down the button until its LED light turns green.
2. Choose the image or text you desire to print onto the CD. On your computer, open the image or text you desire to print. images should be opened by clicking on your computer's "Start" icon and selecting the "Pictures" tab folder within the Start menu. When the Pictures folder opens, click on the image you desire to print onto the CD to enlarge it. If you are planning to print text onto the CD, open the text in Microsoft Word or any other desktop publishing program you may have on your computer.
3. Insert the CD into the printer. Press the "Eject" button that can be found on your CD printing enabled printer. A CD tray will open automatically. Place the CD into the tray print side up. Close the CD tray. The printer will begin working to detect the CD. Once the CD is detected, your printer's LED light will either flash green or another indication color.
4. Print the image or text onto the CD. For image printing, click on the enlarged image's tab that will be on your computer's taskbar. You will see a horizontal row of action icons below the image. Click on the thumbnail image of a printer to print the image onto the disc. For text printing, simply click on the "File" action on the navigation menu in your desktop publishing document. Click "Print" within the "File" drop down menu. The image or text will be sent to the printer once you choose the "Print" action.
5 . Remove the CD from the printing tray. The CD will be fed through the printer during the printing process. Once the process is complete, the CD will come through the bottom of the printing tray. Take the CD from the tray when it reaches the bottom.
The above mentioned steps must help you. In case of any difficulty please revert back.
When nothing worked, I reexamined the trays, and there is a small plastic hook about half an inch long under the left side of the D7460 output tray. The tray below had a small hole. So I clicked the two together, and the printer started printing. Probably like many of you I had elevated the output tray as the printer spews onto the floor. Apparently it needs this connection. So much time lost....
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Make sure you have the proper drivers installed for the printer, then cut and paste the information into a word processor or similar that accomidates the desired print format.
Finally, change the text size and print.
The issue is not with the printer, but the program you are using to facilitate the print job. If this is a web based program, look for a "Printer Friendly" print option on the site.
Alternately, you may have limited success in changing the text size under "View" in your browser, and try printing with the larger text size selected, and in use. If truncating occurs in the printing, then you will have to cut and paste the text into a manageable format, like a Word Processor program.
