Question about Saniflo Sanibest Grinder Pump Only 013
A new saniflo working perfectly for first week has now stopped working. the unit does not run at all
    Sergeant:
  • 399 Answers
Y have a reset butto which may have pinged out try resetting it or it may have overloaded due to a blockage never put paper or towles in them water expanps them and causes this problem
Posted on Nov 14, 2009
Sanislim keeps on running
does anybody know where you can purchase spares for the sanislim just im looking for a replacement motor?
Feb 26, 2013 | Saniflo SaniPlus-Round SaniPlus Macerator...
Toilet bowl, and pump housing are full, drain pipe clear? pump not running correctly. how do i drain it to get acsess to pump?
Prepare to get dirty. Use a mug with a handle to lift the water out of the toilet bowl into a bucket. Reduce the water level until it stops increasing from the backflow from the Saniflo. Disconnect the electrical connections (isolate the unit first) Disconnect the outflow pipe but be prepared for some spillage from any vertical pipe in your domestic installation. Ease the boot off the WC soil pipe, Disconnect any breathers. Slide the unit out from behind the toilet but maintaining a backward tipping angle to prevent water inside the unit from spilling out of the boot. Take the whole unit outside, keeping it tipped backwards. Take the lid off, noting how the seal is oriented for reassembly. Use a high pressure garden hose to clean out the interior and inspect. Check the rubber diaphragm on the bottom of the sensor unit. These develop corrugations and become slack over time. If so it will have insufficient power to depress and release the microswitch within the sensor unit. If your unit filled the toilet bowl with soiled water and the pump kept running, it is likely that the non-return valve beneath the outlet pipe is faulty. On some models the valve is Y shaped and the branch of the Y is a rolling ball that falls by gravity when the pump switches off. Replace the valve. If your unit kept running but with clean water in the bowl, it is likely your diaphragm is faulty. Check for corrugations and make sure it is no longer caked with accumulated solid waste. If you cannot buy a new sensor unit complete with diaphragm, you may need a new Saniflo. Both of my Saniflo units stopped working satisfactorily after 10 years. My German built unit has now been working without fault for 19 years.
Apr 25, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo Saniplus won't stop pumping
is it pumping against gravity? if so there is a non-return flap in the outlet spigot could be stuck or worn.
Apr 10, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo stopped working altogether
It sounds like it has possibly failed. Which fuse did you check .. the fused spur from the consumer unit?
i.e. can you confirm that the unit has power to it?
How old is the unit? , has anything gone down there that shouldn't (toy soldiers, wipes ...)?
It may be worth giving it a clean internally. It could be that the pressure switch is gunked up and no longer working, or that the motor has gone.
If this helps please leave feedback
Feb 08, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Jan 28, 2010 | Saniflo Sanibest macerator with multiple...
When flushed pump starts water goes but pump keeps running when level is reached
pump keeps running - again this is indicative of a dirty / scaled saniflo. You need to clean / descale the saniflo. if this does not work then an outlet pipe blockage (22mm) may have occurred (unlikely if the unit is operating ok). Saniflo sell their own cleaner, which can be introduced via the wc bowl. If this does not work, then its time for a proper clean ( remove unit, jet clean, acid descale, wash, replace). Obviously not everyones cuppa tea.
Oct 27, 2009 | Saniflo & Saniplus& Macerator Pump
It won't stop running
Sounds like the float switch is hung up or burnt out. hope this helps. duane.
Sep 26, 2009 | Saniflo 002/003/005 Saniplus Toilet with...
Water leak from turboflush saniflo
water inlet pipe blows off when toilet is flushed
Nov 11, 2008 | Saniflo 013/005/007 Sanibest Toilet with...
Saniflo Sanibest Grinder Pump Only 013 Logo
635 people viewed this question
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
