Hotpoint ultima extra
Where do i find the filter?
Sorry there is no filter on these hotpoints if anything gets lost it will go straight through the pump ,if it does not pump at any stage check the pump by unscrewing the base plate at the the rear of machine and unblock the pump please make sure you turn off the electrics first good luck.
Posted on Nov 26, 2007
Want to select drying only on a hotpoint ultima dishwasher it has symbols only
the hotpoint ultima fdud4812 is not equiped to select drying only only option is the extra dry button
Nov 23, 2011 | Hotpoint Washing Machines
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Need wiring diagram to conect pcb to a hotpoint ultima extra wma66
www.selfix-uk.co.uk for manuals on WM & WMA machines including wiring connection charts
Feb 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cant find filter on my hotpoint Ultima
Good luck. All modern washers that I know dont have the filter you need. If a clean out is needed you will have to clean out the pump.
Jan 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima extra wma64
hiya
check the wires which run from the motor up to the main pcb, it's quite common for these to rub together and break. i have came across this a number of times now.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima extra WD72
There are 3 possibilities 1 altough the water as drianed the pressure switch as not released due to blocake in the filter, or the interlock has jammed on the closed position which means it will have to forced open or the last fault could be the power board has gone.
Feb 28, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
