Question about Dell Pentium 4, 2.26 GHz (1W391)
I have application error 302
They order to conect application vender
    Sergeant:
  • 270 Answers
Introduction
Your Web server thinks that your URL has been temporarily redirected to another URL. The client system is expected to immediately retry the alternate URL.
302 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with your Web server:
  • Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '302'.
Resolving 302 errors - general
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, a Web browser will immediately retry the alternative URL. So you never actually see a 302 error in a Web browser, unless perhaps you have a corrupt redirection chain e.g. URL A redirects to URL B which in turn redirects back to URL A. If your client is not a Web browser, it should behave in the same way as a Web browser i.e. immediately retry the alternative URL.
If the Web server does not return an alternative URL with the 302 response, then either the Web server sofware itself is defective or your Webmaster has not set up the URL redirection correctly.
Resolving 302 errors - CheckUpDown
Redirection of URLs may occur for low-level URLs (specific URLs within your Web site such as www.isp.com/products/index.html) when you reorganise your web site, but is relatively uncommon for the top-level URLs (such as www.isp.com) which most CheckUpDown users ask us to check. So this error should be fairly infrequent.
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, CheckUpDown automatically tries the alternative URL. This in turn may possibly lead to another redirection which CheckUpDown then tries. This continues for a maximum of 5 redirections. As soon as 5 redirections have occurred, CheckUpDown gives up and reports the 302 error for your account. So you should only ever see the 302 error if 1) your Web server gives no alternative URL on the 302 response or 2) the number of redirections exceeds 5. This second condition should be fairly unlikely - and may indicate a recursive pattern e.g. URL A redirects to URL B which in turn redirects back to URL A.
You first need to check that the IP name we use to check for your account is accurate. If you or your ISP have configured something so that any access using this name should now be redirected to another name, then you need to update your CheckUpDown account to start using the new name.
If you believe that the IP name we use is exact (should not be redirected), please try accessing the current URL using a Web browser. Note carefully which URL actually gets displayed, because your browser may silently switch to a substitute URL if it receives an 302 message from your Web server. If you see any evidence of a new URL, try accessing that directly from your browser. If this works (you see your Web site as expected), then this new URL is what you may need to update on your CheckUpDwon account. If this is a temporary redirection, then you may also need to reinstate the original IP name at a later date when the redirection is no longer effective.
If none of the above help, we can analyse the underlying HTTP data streams we receive from your Web server. These can provide additional information about the new URL(s) which your Web server thinks we should be accessing. Before doing this, we prefer you to identify any deliberate changes on your side, liaising with your ISP if needs be.
302 errors should occur infrequently, because top-level URLs do not change often. If they do change, then this is typically because a redirection URL is being suggested. This pervasive change is unlikely to occur by accident, so most often we can resolve this error by updating our system records for your account following a deliberate change of URL on your part, whether this change is temporary or permanent.
Posted on Aug 07, 2009
Error no. 302?
Control Panel / Administrative Tools / Event Manager
Windows 10 in startup apps go to Administrative Tools / Event Manager
Right Click start menu click event Viewer
once there look to left and expand WIndows Logs Click on Applications and wait for them to load See my pictures i found an error then I clicked on it and it told me what app.
If you don't have event viewer turned on you won't get anything. Then just google turn on event viewer your OS = (winodws 10, Windows 8 etc. turn it on reboot once the error occurs it is recorded go to event viewer and see results.
Dec 30, 2017 | Toshiba Satellite M45-S331 Notebook
Need firing and wiring order for a 302 v-8 with points and cond.,,,,would like a pic if possible got one thats wiried backwards
Aug 22, 2011 | Ford Ranger Cars & Trucks
""an internal error occurred in the initialization
Hi! Welcome to www.fixya.com.
You can go to this website and follow the instructions
http://support.microsoft.com/kb/929135
Thanks for contacting Fixya. Bye for now.
Jul 23, 2011 | Lenovo G460 Laptop Computer 06774CU Intel...
My son's 1525 Dell laptop screen is blank. I hooked it up to a External monitor and ran diags. I received a Error Code 0326 MSG: Error Code 2000-0326 MSG: LCD inverter unable to turn lamp off....
Yep, basically what it means is the ic on the board is shot. Order a new board. Or a complete lcd as it comes with the driver , The choice is yours and its up to you..!!
Apr 27, 2011 | Computers & Internet
What is thge firing order for a v8 lincoln 302 engine 1983
Chilton lists 2 firing orders for a 302 in that year. The regular 302, which is probably what you have, is 1-5-4-2-6-3-7-8. The other firing order is for a 302 HO. If you have this it will likely be marked on the breather. That firing order is1-3-7-2-6-5-4-8. Standing at the front of the car #1 plug is at 1 o'clock on the distributor. 1-2-3-4 is passenger's side front to back and 5-6-7-8 is driver's side for both as well. Hope this helps.
Mar 20, 2011 | Lincoln Mark VI Cars & Trucks
Whats firing order for 1995 ford 302 engine what degrees is timing set at
1995 and later 302 firing order is 1-3-7-2-6-5-4-8
My 1991 302 likes to run at 12 degrees Before Top Dead Center.
Jun 03, 2010 | 1990 Ford F150
Problems with internal
Then its probably dealing with yahoo messanger! Uninstall the program and re-install it! That should do it, if it dosnt, check for viruses, you may have a program containing a virus!
Oct 19, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
509 people viewed this question
Alun Cox
