Question about Whirlpool Refrigerators
2003 Whirlpool 25.4 side by side, Model# ED5SHAXMB00. Icemaker works sporatically. One day it works with no problem, the next it doesn't work at all. Doesn't appear to have any levers to switch, or buttons to flip that I can find.
  • James Allred Aug 02, 2009
    Thank you for your speedy solution. Now, can you tell me where the control module is located on my refrigerator? Again, thanks.
    Solution was very helpful.
  • 3,037 Answers
The Ice Maker control module is at fault and needs to be replaced. You can order a new one from the following website link (2nd part down) http://www.repairclinic.com/Appliance-Parts?s=t-ED5SHAXMB00-%3d%3d
If for some reason the part fails to fix the problem and it would turn out to be faulty wiring which I doubt since these control modules like to fail, it is returnable within 30 days. Let me know how this turns out
Benjamin
Posted on Aug 02, 2009
Whirlpool ED5SHAXMB00 freezer stopped working, then fridge. cleaned underneath completely. fan working. hearing click coming from relay switch on outside of condenser. now what?
This clicking noise is the relay on the side of the compressor. It has been damaged and not working properly. Simply replacing this should be able to start your compressor! I would be VERY surprised if this was not the problem based on your description. I looked up your model number and this is the part number you need - 8201786. This is a kit and the only way to get this part. The instructions should tell you everything you need to know. If I can be of further assistance let me know! good luck!
May 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Whirlpool side by side unit (GS6SHEXNS00) and have experienced chronic problems with the icemaker. I have already replaced it twice. It stopped working again a few months ago and I just couldn't...
Sahal_laher, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Sahal_laher), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Freezers
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool IceMagic Plus not working.
Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
Sep 14, 2009 | Refrigerators
I have a whirlpool refrigerator model# ED5SHAXMB00.
Due to your refrig having the ice bin on the door , it could be a little bit more difficult to diagnose . Pour about 1/2 cup of water into the icemaker . If it doesn't dump , then the problem is the icemaker . When you open the freezer door , does the laser lite flash 2 times then pause then 2 times etc.? If the lite does not flash , it means the icemaker is in the harvest mode (dumping) . If stuck in the harvest mode , replace the icemaker . If the icemaker dumps the frozen cubes , then the black fill tube above the fill cup , could be frozen , or the water inlet valve is bad . If you feel ice in the black tube ,(water valve bad due to slow drop leak ) you'll need to pull the fridge from the wall , and see if there is a plastic coupling on the tube going up to the icemaker . If not , you should get one in case of future problems . Cut the tube (or disconnect the fitting ) (if you can blow thru it , black tube is not stopped up with ice ) and turn the icemaker off . Turn the freezer setting down a number or two . Go by ocassionally to see if you can blow thru the line . This water line goes between the top of refrig and the inner liner . Bad design because if it freezes , no way to get to it . Can try hair dryer on top of refrig . I have known it to take several days for this line to thaw .
Aug 27, 2009 | Refrigerators
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
No ice from icemaker
Read the manual and see if the icemaker has a thermostat that prevents the admission of water into the tray if the freezer temp is too high. Also..make sure the ice level bar is down.
Mar 09, 2009 | GE Monogram ZDI15C Automatic Icemaker
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker doesn't make ice
If there are ice cubes in the icemaker sitting there waiting to be dumped then the icemaker is bad. If the icemaker is dry then it could be the water valve is bad.
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
23 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
