Question about Denon AVR-687
Hi, I'd like to use my Denon at overseas where
Hi, I'd like to use my Denon receiver (AVR 1603/683) at overseas where the power source is 220V. Can I use 200W step down voltage transformer betwwen the 220V plug and the receiver?? Is it safe to operate without damage? Any other/better solution in order to work properly?
Thank you,
Peter
    Guru:
  • 256 Answers
There should be a switch that you could set to the various voltages. Normally a round switch in one of the corners on the rear panel that you can turn with a flat screwdriver
Posted on Aug 03, 2009
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
I have lost video on my tv - connected via hdmi to denon avr-689 receiver.
Had a similar issue, replaced the receiver three times in first month. The fourth time it had to go back to Denon. They returned it saying no fault. Also replaced HDMI cables etc...real head scratcher. Turns out it was the tv. The system can get discombobulated if the receiver, tv and source are not sequenced correctly. This is due to the HDMI protocol, Power up sequence should be receiver, source tv. Once video is lost it has to be rest. With system powered up and tv displaying no signal, remove HDMI cable at tv. Turn off tv at outlet and leave of for 2 minutes (this rests HDMI port, important to leave off long enough!.). Turn tv on and reconnect HDMi...all should be good. Poor Denon, I blamed them when it was my Sony Braiva all along....bad Sony
Apr 16, 2011 | Denon AVR-689 Receiver
Hi, how can i hook up a wireless 5.1 headphone to a denon avr-3808 using an optical connection. I can't find any optical output port on the denon amplifier.
My manual shows two optical outputs labeled "2 (DVR)" and "3 (VCR)" at the upper right of the rear panel.
It's unclear what will appear there when playing any particular analog source.
Feb 26, 2011 | Denon AVR 3808Ci Receiver
No sound from new sony bravia to denon avr 1610
TV's are not your best source of audio. Get the TV-related audio digitally from the source, NOT the TV.
Jun 25, 2010 | Denon AVR-3300 Receiver
I am not able to get audio through my HDMI cables.
It's a monitor - no audio source capabilities.
Get TV-related audio from its original source, not the TV or monitor. TV's and monitors are NOT hi-end audio sources.
Cable box, DVD, BD, games: these are potential hi-fi digital audio sources.
May 25, 2010 | Denon AVR-3300 Receiver
Denon AVR-3300 component channel switch burnout?
hi there, i don't have a solution unfortuantely, but i may have the same problem. I have a denon 2802 av receiver, i bought it second hand and I can't seem to get the component video in / out working. Are you supposed to just plug it in and it works? Because I can't find any buttons or settings to select component in / out as my input / output sources?
Nov 12, 2009 | Denon AVR-3300 Receiver
Hi My denon avr 2600 keeps clips when turn on
Check the polarity (+/-) of the speaker wires. A typical receiver will try to cut the power to the speaker if it's feeding it too much power or too little power to preserve the speaker and/or receiver. That may be the clipping you're hearing. If the wires are reversed, this can cause the same thing.
Aug 15, 2009 | Denon AVR-2600
Help required for dumbo on Amps Denon AVR 2808CI
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
barneyluc
Oct 10, 2008 | Denon AVR 2808Ci Receiver
Can Denon AVR-1403 take 250 volts AC power?
no it will be damged need hi end monster power strip hd700 or better off ebay that will go 1st and alarm will sound on it
Jan 10, 2008 | Denon AVR-1403 Receiver
Denon AVR-687 Logo
224 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
