Question about HP DeskJet 960cse InkJet Printer
Old computer had windows xp. new one too. Using Windows Office. business cards print up with stripes in the colors even when set on normal. Looks similar to draft but the stripes are smaller.
    President:
  • 1,188 Answers
Clean ink cartridges. They may also need to be refilled. Please reply if you know your printer is OK and the problem is with Windows.
Posted on Aug 02, 2009
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Green display on boot up Please help
Check to see that there are no machine BIOS settings that could affect the monitor. Normally, the bios controls display until the OS takes over. If your XP screen after bootup looks fine, I don't see how you have a problem with your monitor setup under Windows.
Jul 03, 2009 | Computers & Internet
Magenta vertical stripe sets plus grid dots problem
Try using a diffrent computer on this and see if its not the video card doing it or if not its the controller board inside that connect to the video card that would need to be replaced at this time, if there are no dead or stuck pixels it might be worth replacing rather then buying a new one.
May 14, 2009 | Acer P191WBD LCD Monitor
Red stripes on my monitor
This looks like a driver issue. Could be incompatible with a software you have installed or bad install.
Use a generic VGA to unintsall and reinstall driver for new card. Turn off computer and then install the new VGA. This should work.
May 09, 2009 | Samsung SyncMaster 214T (Silver) Monitor
Some incoming Outlook emails are very faint
If it is only some emails and not all, you should check the Tools -> Options -> Mail Format -> Fonts section. The 3rd item on that window is for Composing and Reading Plain Text, and it may be set to a color that's not easily distinguishable.
Dec 08, 2008 | Microsoft Office Outlook 2007: Windows
Printer won't print anything but a test page
Check printer settings. Also check windows setting for the printer. Also, be sure the printer is not offline.
Mar 05, 2017 | HP Office Equipment & Supplies
Color printing from Windows XP Photoprinting Wizard
Just dirrerent intrepertations by the driver.
Often times "auto" settings are not the best to use.
You can default it to the best management solution for your computer/printer matchup.
Sounds like a weasly answer I know, but it is amazing how much different those will operate one system to another.
Another suggestion, color normally prints better with a PS, Post Script, driver then a PCL , driver. You may want to go ont the website for your printer and see if there is more then one driver, and switch drivers to see what happens.
Subtle differences in drivers can make a difference how printers print also.
Most of the times it's finding where your printer works best.
It is not necessarly a problem if one setting works better for you over another. Just nuances on different systems.
Please don't take this as a wise comment, but that is why all those adjustments are on drivers and printers, sometimes you just have to modify to get what you really want quality wise.
Hope this helps.
Feb 25, 2008 | HP Photosmart 2610 All-In-One InkJet...
Stripy Boot Up
is it a new graphic card? Sometimes that happens when the graphic card gets overheated and fries up some chips. and sometimes those lines appear when the graphic card has fault in Direct Draw. Try setting your BIOS settings to default. if it doesn't work, i recommend you to take the graphic card to the nearest hardware tech ;)
Oct 16, 2007 | SPARKLE Computer GeForce 6600GT, (128 MB)...
ASUS EN7950 GT 512MB .. pROBLEM!
Hi, I think you will need to run the Dell restore disk, install the orriginal drivers and use the dell system to bootup then load the drivers the ASUS drivers then close the system, install the new card and then bootup. on doing this there will be resident drivers for the new card and it should work fine, then delete the orriginal drivers.
Regards mistyman
Oct 09, 2007 | ASUS EN7900GT/2DHT/256M GeForce® 7900 GT,...
Office-2003
What Kind of Operating System you use? If you're using Windows XP, it's easy just click a print Icon and choose a Business Card Option for Print Style.
Aug 24, 2007 | Microsoft Office Standard for PC
HP DeskJet 960cse InkJet Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
