Question about A4tech Viewcam PK335 Webcam
Bonjour pouvez vous m'expliquer comment installer ma cam a4tech viewcam pro
  • leseur_alima Aug 02, 2009
    je n'arrive pas a installer ma a4tehviewcam pro pk 335 pouvez vous m'aider svp
  • A4tech Master
  • 10,322 Answers
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Nov 22, 2012
geokohler
  • 304 Answers
SOURCE: Driver for A4TECH PK-MAR ViewCam
http://www.a4tech.com/ennew/download%20driver.asp Go to this site and enter your make and model number, on
the next page that comes up click the pc driver button. Once it pops up the download window save it to your desktop
so you have it for future use. Move it to somewhere you will be able to find it if you need it again so you do not have
to download it again! Unzip the file with winzip and run the install program and you will be up and running. If you need
more help feel free to contact me geokohler@gmail.com I will help you for free,I do this for a hobby. Send me your
number and I will walk you through the whole process. Hope this gets you going, If not get in touch and I will help you
until we get it working. Thanks,
George
Posted on Aug 31, 2008
SOURCE: A4tech viewcam pk635M
my problem is likely the same with what others had experienced after installation of my newly procured
A4tech viewcam pk635M.. it says, "you have no video capture, your cam may not be able to function well." and then, it was always looking for a CD labeled 635m installer, when in fact the installer itself which was provided together with the product was already at the cd drive. pls. help..
Posted on Dec 03, 2008
RescueTechLA
  • 2653 Answers
SOURCE: my cam A4tech Viewcam PK336 Web Cam i lost cd
The driver is located HERE.
Please don't forget to rate my solution FixYa.
Thanks!
Posted on Mar 04, 2009
  • 415 Answers
SOURCE: drivers of A4tech Viewcam PK335 Web Cam
Follow the link below for your drivers
it also has directions for dopwnloading.
http://www.a4tech.com/ennew/download%20driver.asp?cmodnum=PK-335MB
Thanks for the rating,
MArk
Posted on Mar 24, 2009
yooperbud
  • 8637 Answers
SOURCE: my web cam is A4 Tech Pk-635M ViewCam Pro.How
Not sure what messenger you are using, so will give you two fixes and if you need the other let me know.
Normal 0 See section B. Yahoo Messenger in the info below to setup the Audio & Video.
Also send this to your family and friends so they have their computer setup properly.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hope this helps. Bud
Posted on Jun 26, 2009
Bonjour, ma riso ks800 marque l'erreur de E4 .Pouvez vous m'aider pour la resoudre SVP? merci d'avance!
HI. E4 REFERS TO "INK OVERFLOW" . CHECK INSIDE THE DRUM, AND CLEAN IF NECESSARY. IF YOU NEED MORE INFO, LET ME KNOW :)
Apr 16, 2012 | Riso RZ390 Duplicator
Bonjour comment l'activer pour pouvoir enregistrer le disc dur de mon portable merci
Bonjour Arnaud,
ce produit est habituellement livr? avec le LaCie Setup Assistant. Une fois celui-ci ex?cut?, votre disque sera disponible sur votre ordinateur.
Le produit est aussi livr? avec le Genie/LaCie Backup Assistant. Une fois install? et ex?cut?, ce programme vous guidera afin que vous configuriez la sauvegarde de vos donn?es vers le disque LaCie.
Si vous croyez avoir effac? par accident le contenu du disque avant d'installer le logiciel, il peut ?tre t?l?charger ?: http://www.lacie.com/download/drivers/LaCie%20Genie%20Backup%20Assistant%208.0.364.534%20Win.zip pour le PC et http://www.lacie.com/download/drivers/LaCie%20Intego%20Backup%20Assistant%201.0.1%20Mac.zip pour le MAC.
Vous pouvez aussi faire une copie directe de vos fichiers vers le disque LaCie comme s'il s'agissait d'un disque local.
Faites moi savoir si vous avez besoin de plus de d?tails.
Jan 29, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
BONJOUR voilà j'ai ma Microsoft life
J'essayerais de trouver le programme d'installation. Vous parlez fran?ais ou espagnol ?
Nov 20, 2010 | Microsoft LifeCam VX-1000 Webcam
Comment proceder pour creer un site twittter
Bonjour, Allez sur le site de twitter: http://twitter.com/ Cliquez sur le bouton jaune a droite: Sign Up Et rentrez vos information comme indique sur la page puis suivez les instructions. Une fois que vous avez cree votre compte vous pouvez commencer a "twitter" en rentrant ce que vous voulez ecrire dans le champ en haut de la page:
Plus de details: http://www.commentcamarche.net/faq/18775-comment-utiliser-twitter
Amusez-vous bien!
Oct 20, 2010 | Twitter Computers & Internet
Bonjour, je veut savoir comment t?l?charg? le driver de canonscan FB630 U. mercie de votre aide
Vous pouvez téléchargé du site internet
http://software.canon-europe.com/products/0000461.asp
On doit choisir la langue et la système d'opération
Jan 05, 2009 | Canon CanoScan FB630U Flatbed Scanner
Bonjour j ai perdu mes driver d une web cam model IT-104WC. si vous plait envoyez moi ces derniers je vous serrez tres reconnaissant. merci
http://www.intextechnologies.com/computer-peripherals.aspx
voyez si vous pouvez localiser le conducteur sur cette page… que vouspouvez également entrer en contact avec eux et demander un conducteur.Robert
Jan 02, 2009 | Cameras
How to switch between tv and vcr dvd or wii?
bonjour j ai le meme remote que la photo ici Jensen ,,, avec le boutton orange, j ai perdu le code pour la television et celui du VCR,,,comment je fait pour le recuperer j ai pas mon livre non plus tout perdu en demenageant et le tout es encore neuf ma television es une Memorex mon VCR un Sanio pouvez vous m aider svp merci ,,,, mon adresse mail,( passionflakes@hotmail.com )
Oct 25, 2008 | Jensen 143307 Remote Control
Je ne suis plus capable de prendre de photo avec ma cam?©ra ???
N'inquite pas. C'est parce-que tu essais de prendre un foto par utiliser le petite button sur la camera. Cela n'est pas correcte. Tu besoin de cliquer sur l'icon pour la camera sur la desktop de votre ordinateur. Quand le fenetre pour Microsoft Lifecam a ouvre, il y ont tres buttons, cliquer sur l'un qui resemble une camera. Voila, ce come ca que tu peut prendre un foto. Bon chance (et pardone-moi pour le francais qui e suelement come ci come ca.)
Jul 24, 2008 | Microsoft LifeCam VX-3000 Web Camera
Bonsoir!!
Bonjour,
Désolé, mais vous ne pouvez pas donner votre numéro personnel sur ce site.
Apr 28, 2008 | Sagem My501X Cellular Phone
Clef de windows xp pro
i wished if you were an English Speaker, i would have tried to help you.
your language is problem to me
Jan 21, 2008 | Microsoft Windows XP Professional
A4tech Viewcam PK335 Webcam Logo
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
