Question about Kodak Cameras
Resetting a Z981 Kodak Digital Camera
What will happen if I reset the camera?
SOURCE:
Rammsteins
  • 300 Answers
SOURCE: kodak digital camera V705 -error 45
Hi!
E45 means that a focus error occurred or the MCU BOARD malfunctioned. I'm afraid you will have to give it away for a repair. It's a hardware problem. You should contact your local Kodak service center.
Tom
Posted on Aug 01, 2009
BillB-SA
  • 2761 Answers
SOURCE: when i put my kodak C913 digital camera on it goes off again
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
fikretunalir
  • 239 Answers
SOURCE: My Kodak M1033 Digital Camera will not focus.
Did you touch your lens before? By mistake or for cleaning purpose?
Did you drop your camera?
If not do the following controls.
One of the followings can solve the problem.
1. Reset Your Camera to manufacturer settings.
2. Turn on the camera and gently pull the lens for placing it to its original position for a moment. Do this untill hearing a click noise.
3. Turn off the camera and change your battery with a fresh charged one or recharge it.
4. Clean the lens gently with a soft cleaning material.
5. Take a picture and change the camera to review mode.
6. Shake the camera to understand if there is a broken parts in it. If there is a free part then your camera should be opened and repaired by an Authorized Service Center.
Regards.
Posted on Jun 03, 2010
lock123
  • 6831 Answers
SOURCE: I lost my manual for
Hello
OK, the manual covers this procedure in detail, you will be able to download the manual HERE.
Hoe this can steer you in the right direction.
Kind regards
Andrea
Posted on Sep 02, 2010
tinualbinale
  • 436 Answers
SOURCE: I have a Kodak EasyShare
You have to transfer the pictures and videos in the internal memory to your computer.For this you have to download and install Kodak software on your computer.
( Make sure the computer is connected to the Internet. When you connect the camera to the computer, the KODAK Software Downloader automatically runs. Follow the prompts to download and install KODAK Software.)
Please follow the steps below to connect your camera to your computer;
1. Turn off the camera.
2. Use the KODAK Camera USB Cable, U-8 to connect camera to computer. (Use only the cable included with this camera!)
3. Turn on the camera.
After the software is installed, follow the prompts to transfer pictures and videos to your computer.
* If the downloader does not run, find and launch it:
• WINDOWS OS: in My Computer
• MAC OS: on your Desktop
Note: You can use the Memory card to save the pictures and videos taken on your camera.In this case you can also use a card reader to transfer your pictures/videos.This prevents the user from connecting the camera every time to transfer data.Eject the memory card and insert it into the card reader.
Please feel free to ask your doubts.Thanks for choosing Fixya.Your valuable feedback would be appreciated.
TinuAlbinAlex
Posted on Aug 07, 2011
I do not have the installation disc for my Kodak Easyshare z981 Digital Camera and my computer won't download or open my videos. As you know the codec for this camera, as well as the software, is no l
Floyd, Download and install Kodak Easy Share Z981 Digital Camera software. Check the attached links Z981 software download,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KODAK EASYSHARE Z981 Digital Camera Firmware WINDOWS Operating Systems
http://resources.kodak.com/support/pdf/en/manuals/urg01118/Z981_xUG_GLB_en.pdf
Kodak Driver Downloads
May 05, 2014 | Kodak EasyShare Z981 Digital Camera
Where is the reset button on a Kodak Z981
There is no reset button on the Z981. There is a "Reset Camera" command in the Setup menu, as described toward the bottom of this page.
Jun 19, 2012 | Kodak EasyShare Z981 Digital Camera
Reset button on a Kodak Z981
Jun 19, 2012 | Panasonic Lumix DMC-FZ5 Digital Camera
Batteries Corrodided in camera
Try taking a #2 pencil and use the eraser on the contacts inside the camera to clean them off. Dont use anything to rough.
If this doesn't work try taking it to a local camera shop to get them to send it off for repair.
Nov 24, 2011 | Kodak EasyShare Z981 Digital Camera
Can't seem to download manual for Kodak Easy Share Digital Camera Z981?
This question-post has duplicated; check the answer in this previous question: find_manual_z981kodak_easy_share
Good luck.
Oct 18, 2011 | Kodak EasyShare Z981 Digital Camera
Z981 will not download photos to computer either thru USB port nor Kodak Easyshare software????
using the memory card is often better than the software and/or USB cable. the memory card is a more moern way of getting pics from your digital camera to your pc or laptop.
Mar 31, 2011 | Kodak EasyShare Z981 Digital Camera
Can the date be put on pictures from the z981
According to the Kodak website the Z981 can be set up for date stamp. I could not locate a users guide, but it mentions it under Custom settings.
Jan 15, 2011 | Kodak EasyShare Z981 Digital Camera
I want an extended user manuel for an kodak z981 camera
You can view it online and/or download a PDF version from the manufacturer's web site at
http://support.en.kodak.com/app/answers/detail/a_id/19290/kw/z981
Jan 05, 2011 | Kodak C183 Digital Camera
Cameras Logo
66 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
