Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
Viking Dual Fuel 6 Burner 48" OVEN DOES NOT HEAT
The oven is not heating, which is strange and more than coincidental in that it occured the day after Thanksgiving when all worked well. So, I'm wondering if it needs reset, or something happened after my wife cleaned it. Power is fine, temp control light comes on, fan works for convection, but the light adjacent to the oven function (broil, bake, etc) knob does not light. Oven does not work in broil or bake mode. Sure don't want to spend $200. if it is a small problem I can cure myself.
  • 3 more comments
  • Anonymous Jan 17, 2008
    Same problem has plagued our 5 year old model from the start. Serviceman first suggested kicking the lower right side base panel since the controller is located behind that. That worked twice but now has died completly.
  • Anonymous Mar 26, 2008
    Exactly the same problem as posted. No resolution yet. Please help
  • Anonymous May 07, 2008
    Yes, the same thing is happening to me. I cleaned the oven a couple of days ago. This is the first time I have tried it since. The oven elements get warm, but no more than that. Lights, fan work. No heat or broil.
  • Anonymous Sep 18, 2008
    The problem I am experiencing is similar, When I turn the oven on there is a glow from both sides. After a few minutes the gas flows to the left oven burner. I replaced the gas valve and still have the same problem. If I disconnect the left side the right side will ignite. Any thoughts??
  • Anonymous Jan 25, 2009
    I am having the same problem listed here, either one side or no sides will light in the oven. Both sides glow and then one side will light , if you tap the valve the other side will light, but once the oven cycles off it will not come back on by itself. Replaced ignitors and gas valve. Was also told to kick lower part or oven.
  • 23 Answers
I hate self clean functions - If you think about it - you should too. These ranges are equipped with electronic components and running self clean at 950 degrees will more than likely burn something out. A lot of complaints are because of the self clean. It's not worth it to self clean than to clean it yourself. And 200 dollars is a great price for something like this if it includes parts and labor. Good luck.
Posted on Sep 18, 2009
VDSC4876GSSLP - Oven element wont heat . . Main oven started going in and out of "clean" mode, locking and unlocking the oven door while in use, then eventually stopped working all together. Fan and light...
If there is power to the unit (lights turn on) I would check the fuses and switches especially the one for door lock mechanism if you noticed a glitch. But a lot of times if you experiences problems after running a self-cleaning function, including locked door issue, the solution could be as simple as resetting a switch and no actual replacement parts needed. It all depends. If you are in Los Angeles, we could send a Viking repairman the same day you call us. : Viking Appliance Repair
Dec 08, 2014 | Viking 48" 6 Burner, 12" Grill Gas...
Oven shuts down
they both use 220 and , you have to put it on different breaker , that can handel 32 amps.
Feb 26, 2014 | Viking 48" 6 Burner, Griddle Professional...
I have 48 " 6 burner stove natural gas.Stove is
the glass in the ovens should not crack when self clean is used. it could be that there was a minut crack in the glass or a build up of moisture in between to door windows that expanded at the extra heat but this should be brought up with the manufacturer for replacement.
I hope this was useful.
Jan 05, 2011 | Viking 48" 6 Burner, Griddle Professional...
Viking model vdsc4874gss small oven works fine large oven element on bottom only gets hot in cleaniong mode, fan comes on when dial is turned to convection but no heat power is on light works
One thing that you can check is make sure that you have 220 volts at the plug. Leave the unit unplugged and check continuity on the burners. You should have continuity on the burners.
Oct 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Viking oven not heating past 150 degrees
My viking oven had same issue - I needed to replace the ceramic ignitors (if ignitors fail to heat up properly the gas valve remains partially closed). Apparently they are intended to be replaced every 3-5 years. Also inspect and clean the oven burners - mine had corroded somewhat and prevented the flame from 'moving' to the opposite side - ie only half the burner was lighting. If you are handy the ignitors are very easy to replace - one screw, two wires each.
Jan 02, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Basically my gas oven is not heating up properly, the temperature is not hot at all, and food is not getting cooked properly
this is a milti burner unit / and sounds like the ignitors or weak / look below the oven door edge for a glow if orange there bad they need to be white hot .. burners may come on but not all the time .. ****
Dec 05, 2009 | Viking 48" 6 Burner, Griddle Professional...
Oven will not work
It sounds like the Thermostat is defective.
Element can be removed from the front of the unit, it does not need to be pulled
Oct 27, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
640 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
