Question about KLH Audio Players & Recorders
Find a fuse retailer
KLH Bassbite 5 subwoofer fuse
  • KLH Master
  • 5,686 Answers
If you can post a picture of the fuse it might help in tracking one down.
However I should point out that fuses rarely blow on their own. And one blown is a sign of a serious overload, probably in the main amp or power supply section.
Posted on Jul 09, 2018
3 Suggested Answers
SOURCE:
dunnbiker
  • 8546 Answers
SOURCE: KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Posted on Jan 31, 2010
sean1dave
  • 7 Answers
SOURCE: how do i connect my
http://www.docs.sony.com/release/STRDE335.PDF
I am basing hookup on my Bassbite !! manual. The procedure should be the same as on your Bassbite V
I have given you a link to your Sony Owner manual. It looks like you will connect your sub to the sub output on the rear of your reciever using the rca cable. Woofer out on the Sony to the R/Mono input on your Bassbite. If you have the front and rear speakers hook your rears into the rear speaker outputs then connect your front speakers to the front speaker outputs of your Sony. Your speaker jacks on the Bassbite will not be used for this configuration.
Now, adjust your speaker size setting for "SMALL" or "LARGE" speakers as appropriate for your setup (this is for the front and rear speakers and will not effect your Bassbite). Now set your Sony subwoofer output to "ON" You access this setting through your menu. That should be located on your remote for the Sony. You will want to refer to the manual to find the exact method to access your system menu.
If the link to your manual doesn't work for you then go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDE335 and click on Operating instructions.
Hope this helps. Let me know okay? By the way, if this works for you you should be very pleased with the sound quality :-)
Kindly, DAVID (sean1dave)
Posted on Mar 07, 2011
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Can I hookup a Sony receiver STR-DE505 to a Bassbite 2 KLH Audio system and how??
Yes.
It's frustrating that KLH manuals seem impossible to find anywhere online BUT a simple picture will suffice...
Go here and supersize the picture of the rear of the sub...
http://cgi.ebay.com/KLH-Audio-Systems-Bassbite-V-Model-E214708-Speaker-/110673631693
Run your front channel speaker wires to the CLEARLY-MARKED connectors on the sub and daisy-chain your front speakers to the CLEARLY-MARKED connectors on the sub.
Adjust the sub volume to match the front speakers levels. This will give you local volume control at the Sony.
Jun 04, 2011 | KLH BB-II Subwoofer
How do i connect my klh bassbite V subwoofer to my sony receiver model str de335?
Feb 26, 2011 | KLH ASW10-120 Subwoofer
Need a product manual for a klh 9906 home theater system with 4 satellite speakers a center speaker and a bassbite II
Try the KLH site. I have downloaded (for free) info on KLH products. Not much on technical stuff, but set up info and connections.
Jun 12, 2010 | KLH BB-II Subwoofer
I have a KLH bassbite II sub, not sure how to connect it to my receiver. Can you help? There are 4 wire amp inputs and 4 speaker wire outputs which I am assuming are right and left channels. There are...
Forget the 4 wire inputs on the sub as you have pointed out. use the low mono input only.this can be plugged into any audio out connections at the amplifier.so it is one rca/low wire from sub to amplifier then plug in power cord and adjust volume as desired.
Mar 06, 2010 | Audio Players & Recorders
Jan 31, 2010 | KLH ASW10-120 Subwoofer
Loud hHum from Subwoofer
Sounds like the hum might be mains hum caused by the failure of the power supply capacitor(s) in the sub. It/they will be the largest on the pc board. You will find all the details (needed to replace it) on them. If you find more than one replace both.
Dec 10, 2009 | Audio Players & Recorders
It is a klh powered subwoofer, which buzzes when plugged in, even though the power switch is set to "off"
Sounds like the grounds are screwed up. Try using a grounded wire for the subwoofer input. If that doesn't work, it sounds like something is internally screwed up, like the power supply doesn't fully power down. I guess besides buying a new amp, just connect it to a power strip where the switch is accesable and shut the sub off with the power supply.
Oct 10, 2009 | Audio Players & Recorders
Subwoofer VERY weak
According to the KLH manual for the 9906 "6 pack" with the BassBite sub... it says "if your sub is connected via the speaker - level terminals, your reciever must be set for "NO" subwoofer - even though you are using one. VErify proper polarity on your speaker connection wires. (red or gold to +, black or silver to -). Depending on how you have your woofer connected to the reciever, if connected to a reciever without a subwoofer out then set your reciever for LARGE speakers and turn the subwoofer setting "OFF". Failure to do so will result in little to no bass. If you do have a subwoofer out from your reciever adjust your speaker size setting to small or large speakers as appropriate. Set the recievers sub output to ON. Connecting small speakers to a reciever set for LArge speakers can result in damage to small speakers.
Hope this helps.
Jan 14, 2007 | KLH HTA-4100 System
135 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
