Question about Garden
Fuel leak on craftsman pushmower with Honda engine.
I have a craftsman pushmower with a Honda easystart engine. I was away on vacation for two weeks so the mower wasn't used (and the lawn wasn't cut). Upon returning I set the blade to the highest cut level (because the lawn was higher than normal). The mower cut fine. After finishing, I turned the mower on its side (as I always do) to clean out the underside of grass. When I turned the mower back up, I noticed a gas leak by the airfilter. It's a steady leak and it did empty the tank. Any suggestions?
    Scholar:
  • 135 Answers
Sounds like you tilted the unit enough to cause the float in the carb to open too much and therefore, the needle valve inside is stuck.
Remove the bowl and let it resit itself and then re install the bowl. If that doesn't work you may need to purchase a new kit for the carb to get the needle valve. If you find a small minut ring around the face of the needle valve replace it. That's why it's gonna leak. Good luck
Posted on Aug 02, 2009
Craftsman 6.50 pushmower
Replace spark plug. Replace air filter. Fill oil. 30w. Automatic governor no adjustments.
Jul 13, 2013 | Craftsman Garden
I have a Husqvarna 55R21HV mower. Last week I stupidly hit a rock hidden in long grass and bent the crankshaft. I can pick up a spare engine off a Flymo XL500 or an engine alone advertised as having a...
Generally the bolt pattern is the same for most small pushmowers. If in question I recommend taking measurements, but when I went to swap engines on a pushmower they were the same, even with an almost 3 HP difference in rating.
In regards to changing the crankshaft, it involves the complete teardown of the engine to replace. Most people just replace the engine.
Jul 18, 2011 | Garden
Fuel leaking at tank when motor is running, stops when engine is off 1992 Honda Accord
The fuel pump for this car is electric and is located inside the fuel tank, so you have a leaking fuel line, when the pump is running you have a leak, when the engine is shut off the pressure goes away and no leak.
Mar 29, 2011 | 1992 Honda Accord
Engine runs for a few minutes then stalls...
It sounds like vapor lock or other lack of fuel. Premium gas will cause detonation and "may" have something to do with it. Drain the fuel the best you can and add regular fuel, after a couple minutes the engine should be burning mixed fuel and if the problem goes away you have fixed it, if not you obviously have other issues.
Jun 19, 2010 | Craftsman 2500 PSI Briggs Stratton...
I have a Craftsman YT4000 which is leaking oil from the fuel pump? What is my problem?
I have the same mower, 18.5hp and mine is leaking oil from the fuel pump. I replaced the fuel pump and the same issue. Sears came out and could not duplicate the problem. Changed all the oil, plug, filter(s), etc and ran for about 2 weeks...now it is doing it again. At $100 a whack, Sears is making a killing on saying I don't know.
May 07, 2010 | Craftsman Garden
I have a 01 honda accord 2.3l it has a obd fault code p1456, can any one tell me what this code means?
smal evap leak detected....very common check your fuel cap make sure it't tightened at least three clicks-check the o-ring of the cap as this will
cause a leak as well. drive vehicle the code will clear it's self if it odes not go away after 1 week of continuos driving it may have a larger leak
in this case you need to see a dealership-they will perform evap function test and determine if problem is worse-1457 is the bad one indicates large leak and can be expensive,. hope this helps.
Apr 15, 2010 | 2001 Honda Accord
Where is the fuel relay located in Mazda mx6 1988?
On that one it actually called circuit opening relay under left side of dash in fuse relay box
Feb 08, 2010 | 1988 Mazda MX-6
1991 honda civic wagon. would not restart after
SOUND LIKE ENGINE IS FLOODING. FUEL INJECTORS IS LEAKING FUEL WITH ENGINE OFF.TRY FILLING GAS TANK UP.AND PUT A BOTTLE OF FUEL INJECTION CLEANER IN GAS TANK DRIVE AROUND A LITTLE SO THE CLEANER CAN CLEAN INJECTORS.
Sep 10, 2009 | 1991 Honda Civic
Help!
on the murry try the batt earth lead and on the push mower if the mower has been tipped up oilcan go into the air filter if the filter is fome wash it out in some fuel to clean dry and put back on engine if mower starts it will take 5 min for oil to burn out of the exhaust muffler allso clean the s plug when tipping a mower allways keep the s plug up words and all will be good
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2009 ford fusion engine light stays on steady
You just have to disconnect the battery for 1/2 hour. then reconnect and drive for 10 miles so computer can relearn your engine again. It may run rough. You should have the key off when refueling because computer sensed a fuel vapor leak during fueling and turned the light on.
Also, you can always drive with a check engine light on. It just means you are not meeting emissions. Do not drive if it's flashing on and off.
May 23, 2009 | 2006 Ford Fusion
Garden Logo
257 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
