Nobilis Laptop. Can't shut off touchpad
I have a Nobilis laptop. I use a mouse with it and would like to shut off the touchpad thats below the keyboard. My kids can't even figure it out.
  • 63 Answers
SOURCE: "sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Posted on Nov 16, 2007
  • 3 Answers
SOURCE: laptop keyboard not working in compaqv3000.
i reinstall all the driver of my vista laptop drive especially bios and restart my computer and this solve my problem.
Posted on Feb 13, 2008
SOURCE: touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
Posted on Sep 05, 2008
CheTzu
  • 3 Answers
SOURCE: toshiba satellite touchpad & keyboard stopped working
As I understand your keyboard is now working and your usb mouse. But the touchpad does not work.
Have you or someone opened up your laptop recently? If so it is possible the touchpad was not connected properly.
Can you please post the exact name of your laptop. I'll see what else I can figure out for you.
Posted on Oct 03, 2008
SOURCE: Cordless mouse
Just a thought, perhaps you could borrow a usb cable mouse. Tell the comp to detect the wireless mouse, then unplug the usb mouse.
Posted on Nov 02, 2008
Dell inspirion n5030 laptop
Are you using the touchpad, or a regular mouse plugged into the laptop. If you are using the touchpad on the laptop, make sure it is enabled. There is a button to the right of the F12 key to enable/disable the touchpad. If you are using an external mouse connected to the laptop, try restarting the computer by pressing the power button once (that will initiate a shut down).
Nov 23, 2013 | Computers & Internet
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
Lo scroll touchpad non funziona samsung p530
google translated
touchpad scroll does not work samsung
Feb 07, 2013 | Samsung P530 Notebook
My Advent 5421 Touchpad Is Not Working!!!
Advent laptop computers are equipped with a touchpad and two buttons that service the function of an external mouse. The touchpad can be turned on or deactivated, depending on the user's preference. It's not difficult to either activate or deactivate it.
Power up the computer. Connect a plug-and-play computer mouse to a free USB port on the laptop. The mouse is just temporary to help you get the touchpad working again. Locate the touchpad icon, which is in the lower right-hand side of the screen. The icon will appear as a gray square or rectangle, with two rectangular buttons underneath. Use the mouse to double-click on the touchpad icon, opening a window on your laptop screen. Inside the touchpad window, click the option labeled "Enable Device". Select other options for the touchpad, such as pointer speed and shape. Click "Apply", then "OK". Disconnect the mouse from the laptop.
Feb 02, 2013 | Advent Computers & Internet
The touchpad mouse on my toshiba salellite does not function even though it shows it working properly when you go into the touchpad icon. I have an external wireless mouse (usb) hooked up that works fine...
The touchpad is most probably defective. If you have dropped your laptop the touchpad cable could have get out from its connector on the mainboard. You can get a new touchpad/palmrest on ebay. You have to remove your touchpad/palmrest as shown in the link below, steps 17 to 19 :
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
Identify the part number of your touchpad/palmrest. Search on ebay.com : Toshiba Satelitte A105 palmrest. Buy the one with the same part numer as yours.
...or have your laptop repaired by a professional.
Oct 09, 2009 | Toshiba Satellite A105 Notebook
My acer aspire touchpad frozes
right click My Computer >> Manage >> Device Manager.
See if the drivers are installed
May 22, 2009 | Acer Aspire One PC Notebook
Nobilis laptop overheat?
Nobilis Has HEAPS OF PROBLEMS! take it to an expert computer shop and they will fix it.
Apr 21, 2009 | Computers & Internet
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
456 people viewed this question
David Payne
David Payne
