Question about Franke Kindred DP2233/90/1 Granite Double Bowl Sink Polar White
How do you clamp down sink? - Franke Kindred DP2233/90/1 Granite Double Bowl Sink Polar White
  • 88 Answers
There should be clamps with threaded bolts in the box or already attached to sink one for each corner they over lap to catch counter just line them up and tighten if you dont have you can get replacements at hardware store
Posted on Aug 23, 2009
My porcclain drop in bathroom sink has no clamp tabs to attach clips to,how to fix
Go to Home Depot and buy some sink screws that go into tab that you attach the screw into the wood and the tab over the underside of sink. They also carry other stuff that works even better.
Apr 29, 2014 | Home
Trouble with a Franke kitchen faucet - the spout has a retractable internal hose for spraying down the sink - it is not retracting as it should
Look at the clutter under the sink. Is the hose tangled or caught on something? There should be a weight clamped to the hose to make it fall back into place. This weight minght have slid down the hose.
Jul 17, 2010 | Franke FF-303 Kitchen Faucet with...
How do we install the clips on the bottom of a top mount sink
The clip with the screw together, with the screw head down and the claw up, go into the channel on the underside of the sink, they go through a slot in the channel then slide to fit about 3 or 4 on each side. Tighten up the screw and it should pull the sink down and clamp onto the wood under side of the counter top. Put a bead of siliconized latex caulk around the edge of the sink before dropping it in, DO NOT USE SILICONE!!!, then with a wet rag, clean it off what gurks out. You should be all set.
May 19, 2010 | Home
There were no instructions to install my undermount sink. What can I do?
Most under mount sinks are installed before the counter tops go in, they are cut to fit and glued in with 2 part epoxys and secured with screws and clamps. Replacing one in an existing counter top is not an easy job. If you have a granite top, forget it. If it is wood and formica, ok, you can pull the splash off and remove the top, but it is a lot of work. You would be better off with a new top, or a new sink, rim type. Now if you are building a new house and this is new construction, then you can do it no problem. And depending on what kind of top it is, it needs to be screwed and glued. The guy here that did granite for us, would drill out little holes, about 1/4 inch dia, and 1/2 deep for these little machine inserts to go into. Epoxy them in, then clamp the sink down or up to the top with machine screws, about 10/24, 1/2 inch long. Through a clamp, and epoxy the top on, sometimes he used clear silicone. depended on the top. If it was wood, you would just screw into the wood with 1/2 inch pan heads. Hope this helps.
May 15, 2010 | Franke 34" Undermount Double Bowl...
Is it necessary to clamp down a granite graphite sink or will silicone be enough?
The makes the clamps for a reason, I would suggest you use them.
Good Luck,
Gil
Mar 01, 2010 | Franke Kindred DGR2233/90/1 Granite Double...
Heat sink
the heatsink needs to be clamped down to the cpu. if there is a clamp missing i would not use the pc until it is replaced.
Jul 14, 2009 | Dell Dimension 4600C PC Desktop
How to remove a cast iron kitchen sink installed
Turn the water supplies off unscrew the hoses,get a flashlight and look under the sink you should see clamps around the top holding it in, unscrew these and pull the sink out.
Len
Feb 22, 2009 | Eljer 212-1088-00 White Dumount Double...
How do you remove the heat sink from the CPU?
This depends on the CPU and the heat sink. The heat sink is fastened to the socket on the motherboard on two sides. It will be fastened to a tab on each side. In all likelyhood, the heat sink will have some sort of handle on it. AMD processors these days have a little lever that must be moved from the far right position up to the center. This loosens the heat sink and you can reach down to unhook first the side with the lever from the socket and then the back side. Intel processors seem to have a flat metal piece that must be pushed down to relieve tension on the clamp. As you do so, you have to get down by the socket on the motherboard and push the metal clamp away from the socket. This takes some doing, as it's quite tight. Once you have released the one side, the second side is loose and can be unfastened.
The heat sink can now be pulled up (use a slight twisting motion if possible to break the seal between the heat sink and the CPU. If the computer is several years old, the seal will be hard to break.
Feb 05, 2009 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
Installing a drop-in sink
The stone installer told you to use silicone,
what makes you think that you know more than he does about his product.
IF you go use lockdown screws, you will put tension on a thin granite slab at 4 or 6 points around the perimeter of a hole.
stone breaks under very small tensions
do as instructed and silicone the sink in place,
or void any warranty and buy the counter top again when you break it
formica is plastic on a chipboard substrate -not stone
not perhaps the answer you want to hear,
Sep 09, 2008 | Air Tools & Compressors
Franke Kindred DP2233/90/1 Granite Double Bowl Sink Polar White Logo
390 people viewed this question
Top Franke Home Experts
Donni Steen
Gil Shultz
Freddy
Are you a Franke Home Expert? Answer questions, earn points and help others
