Question about Troy Bilt 5.5hp Self Propelled Mower
Troybilt riding lawnmower - won't start
Turn the key and nothing happens. Replaced solenoid - still nothing.
Tried bypassing solenoid, key turned to on, mower in neutral, jumper cables used on each terminal on solenoid - nothing happens.
Tried bypassing ignition system, connected jumper to positive post on battery - & tapped on the starter bolt. Got sparks - starter engaged, but very sluggish like there was way too much friction either inside starter or on flywheel.
Mower is only about 5 years old - any suggestions greatly appreciated. I'm reluctant to take it to a shop - prefer to do any repairs myself.
Thanks - Jim
  • Jim Abegglen Aug 02, 2009
    PTO engagement is from a lever pushed away from driver - switch is engaged only when lever is forward. What do you think would cause the slow turn of the starter/motor when starter is jumped?
I have a troy built riding mower, just replaced battery, when i turn key sounds like battery is dead. what could be the problem?
Posted on Mar 28, 2010
    Novelist:
  • 133 Answers
Check whatever you use to engage the blades. If it is a leaver that you have to raise and lock into position it might need wiggled to engage a switch. Try wiggling it while you are turning the key.
Posted on Aug 02, 2009
  • roundo4 Aug 07, 2009
    How old is the battery? I had a tractor that I put a new battery in and tried to start it to load it on my trailer to get it home and it would not start. When I turned the key there was nothing. I have a hand crank wench on my trailer and that's how I loaded it. When I drove to my house about 10 miles away I jumped on it to try my luck and what do you know it started right up. From me driving on PA' s nice smooth roads it moved the PTO lever a little. I don't know if there is an adjustment for it, I just live with the problem.
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Craftsman wont do anything wont turn over or fire at all.
When I turn the key nothing happens.
There are several elements that go into cranking (turning over) the engine.
  1. Battery
  2. Fuse
  3. Key Switch (and wiring)
  4. Starter Solenoid and wires
  5. Starter motor
Let's start with the battery. The quickest way to make your initial check of the entire starting system and particularly the battery is to get a jump. Yep, get some jumper cables and jump the mower off your car. Turn the key and try to start it in the normal fashion. If it starts cool! It is likely a bad battery.
  • Charge the battery for a few hours, on a charger.
  • Then perform a voltage measurement of the battery.
  • Switch a volt meter to DC Volts and clip it to the battery. It should read between 12-13 volts. If not the battery is suspect.
Now let's check the starting system while bypassing all the safety switches and wiring. How? You can perform this test simply by jumping the starter solenoid. Hold a wrench or fat screwdriver across the two large posts of the starter solenoid. This bypasses the key switch and all safety devices and directly drives the starter. Your starter will crank if the battery and starter are good, the wires and connections are good, and the engine is not locked up. Don't crank it for more that a couple seconds. You just want to verify the battery and the starter are both in good shape. (The engine will crank but not start during this test if the key is off, or if the safety switches or wiring are damaged, or if the safety switches are in the no start/run positions.)
If the starter cranks try one more test. Run a small jumper wire from the positive post of the battery to the little terminal on the solenoid. You may have to take the small wire off the terminal, on the starter solenoid, in order to do this. When you apply this current from the battery to the terminal it should make the solenoid activate and the starter crank. This test bypasses the key switch and shows you the starter system is working. You could do this test first; if it works you do not need to do the basic jump test.
If these tests cause the engine to crank, but it will not crank with the key, then you know you have a problem somewhere in your starter wiring, safety switch system, fuse, or in your Key Switch. Of course you did check the battery terminals for good connection, right?
Most modern riding mowers have the following safety switches:
  • Seat switch
  • PTO switch
  • Reverse switch (RIS) and Reverse Relay (RIO)
  • Brake/Clutch switch
If you need detailed instruction for testing your wiring and safety system, I will need your complete machine info.
  • Make
  • Model
  • Year
  • Engine Model
  • Transmission Model
  • Deck Size.
On a John Deere (100 series) the starting current flows through the following items in this order:
  1. Battery to Fuse then to the Key Switch.
  2. With key switch in the start position, the current flows from the Key Switch to PTO.
  3. With PTO off, current flows from the PTO to Brake/Clutch
  4. With Brake/Clutch Pedal all the way down, the current flows to the starter solenoid.
  5. If the Starter Solenoid is in good shape, the solenoid connects the battery to the Starter and the engine cranks. Cranking does not mean running; it just means the engine turns over. Running is dependent on many other systems.
Those components are all part of the cranking/starting system. They can prevent the Starter Motor from cranking when you turn the Key Switch. You can trace the voltage with a multi-meter. Connect the black lead to ground and look for 12 volts on each successive step. If the voltage disappears at one particular step, there is your suspect.
Electrical elements that are NOT part of the starting system:
The RIO is the Reverse Implement Option. It is a switch that latches and stays latched under certain conditions. It is activated by the RIS. The RIS is the Reverse Implement Switch. It activates the RIO. These two separate components work to allow the blades to cut while you are backing up (without killing the engine). They have nothing to do with the starting system.
The Seat and the RIO (the reverse latch not the button) switches are tied into the engine kill system.They provide a ground path for grounding the Coil. This same system controls the fuel shut off valve beneath the carburetor. The Seat and RIO can keep the engine from running but they will not prevent the Starter Motor from cranking. Therefore, if you turn the key and nothing happens, the problem has nothing to do with the Seat and Reverse switches.
Note: With the Key in the RUN position, power flows from the Key Switch to the Hour Meter, then to the RIO latch relay (not the RIS button), then to the fuel shut off solenoid. If you do not hear the Fuel Shut off Solenoid clicking on and off when you turn the Key Switch from off to run, there may be a problem in this circuit; including a possible problem in the Hour Meter. Of course none of this affects the cranking circuit. Your engine will still crank, it just won't run.
Apr 12, 2015 | Craftsman Lt1500
Electrical diagrams for husqvarna riding lawnmowers
Does it turn over? Is your start fuse ok? Located just behind engine.
Use a ohm meter see if you have 12v at starter, turn the key to get reading.
Jun 06, 2012 | Garden
I have a yth20k46 and when I turn the switch it won't turn over. I replaced the battery and spark plugs. what might be the problem
I also have a YTH20K46. During last mow (last week), I tried to turn off mower and would not turn off by key. I had to put it down to choke and then stand up. It created a backfire. Today I went to start it, now won't start. It does not turn over. Hour meter has no power. Tested battery & solenoid. Power to both. Key switch works fine. Any suggestions? Just had it serviced a few months ago. Oil, gas and all other things seem fine. Checked wiring, seems fine. Nothing melted or cut. Please help!
May 23, 2012 | Husqvarna Garden
Ingnition problem
Sounds like it could be the switch, you can bypass the ignition switch and touch the two positive wires together from the solenoid to see if it cranks over. Be very careful make sure it is in not in gear.
May 17, 2012 | 1966 Ford Mustang
John deere gx85 solenoid
try bypassing the safety switches with a paper clip to see witch one is bad
Apr 20, 2012 | John Deere Garden
1989 camaro rs won't turn over replaced starter
You need reprogramme the replaced starter.
Apr 13, 2012 | 1989 Chevrolet Camaro
Sprayed down lawnmower with water, now it won't start. I decided to "wash" the lawnmower last week and now it won't start. And the really weird part is the solenoid clicks every minute...
Engine will not run with no spark or a weak spark. Continuity test will only reveal that the winding is not open, not if you are producing a weak spark that will not jump the spark plug gap.
Mar 31, 2017 | Garden
Have a craftsman 17.5 hp bought 7 or 8 years ago. Has "LT 1000" on its engine cover. Went to start it. Turned the key in the ignition, "nothing happened, checked battery, appear,o.k. The battery guage...
Yes, you may hear a small click when the key is placed in the run position. It is the fuel solenoid (on the carburetor) activating.
If it is a large click, then that is the pto clutch activating (as in the blades are ON) and that will not allow the engine to start.
Sometimes when a battery is low or connections at the battery are dirty, you will hear a click, that is the solenoid activating, but the battery voltage is low enough that the starter will not turn. Sometimes this condition has a chatter.
Easiest test for this situation is jump start from you automobile, or charge the battery for an hour, and see what happens from there.
Nov 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Troy Bilt 5.5hp Self Propelled Mower Logo
2,450 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
