Question about Plumbing
Moved into house with damaged joint in external soil pipe from upstaira shower room
  • Sheena Aug 02, 2009
    hi there, sorry about that!
    its 110mm, black polypipe.
    we thought of doing something like you suggest, but the damage is on the lower joint of the soil coupling coming thru the wall from the loo.
    we tried to get new seals, but over here in ROI, seems theyre an integral part of the coupling.
    my handy husband is thinking of just cleaning the joint as best he can, then using waterproof sealer and wrapping waterproof tape round the outside.
    we're in rented accomodation and only want to do an in-expensive repair until the landlord pays to have it done properly
    Genius:
  • 1,114 Answers
You didn't state the size of the pipe or if it is PVC(plastic) or Cast iron. Two rubber couplings can be used to repair the joint. A 12" section, 6" on either side of the joint needs to be cut out. Cut a piece of schedule 40 drain/waste pipe same diameter as existing pipe to size(just under 12"). Take two rubber couplings (sized for your pipe) and place on each end of pipe joint, and tighten clamps.
This fix will work on cast iron pipe, but there may be another means of repairing the joint, so get back to me with more info about the pipe and joint.
Posted on Aug 02, 2009
  • Joel Friedenberg Aug 02, 2009
    Yes, water proof sealer / tape can work. Also, If you take some rubber material and wrap it around the joint over the sealer and tape, it will hold everything in place. Use two large Hose Clamps to hold the rubber in place.
Hammering or knocking
If you do not have an expansion tube on your hot water heater that might help.
Feb 12, 2018 | Jado Home
Ican't get wirless anywhere in side house except the room router is in. Are there longer extensions so i can move router to another room? Or what is your suggestion?
I've never seen cinder block affect wireless signal before. Metal pipes and ducts can interfere as can electromagnetic interference from appliances and ungrounded wires.
If possible, moving it to a location higher up, like a second floor of the home, could help broaden the range. Also, check to make sure that that there aren't any wires grounding out on places they shouldn't be (pipes and ducts).
Aside from purchasing expensive external antennae, moving the router through trial and error is probably your best bet.
Oct 23, 2012 | Computers & Internet
Water coming from the back of the shower
most likelt your home has copper water pipes. If the shower head's pipe has any movement the sweated solder joint is most likely cracked causing the leak inside the wall. If it is mounted securelt one of the sweated connections has a faulty solder joint that needs to be resoldered
Aug 19, 2011 | Home
I want to install a new shwer head fixture. I am having difficulty removing the ball joint adapter. any ideas?
You have to remove the whole pipe going into the wall, the ball is not seperate. Use a pipe wrench or something similar to remove it. A new showerhead pipe needs teflon tape wrapped clockwise on the threads and screwed into the fitting inside the wall. Now you can install any shower head you want.
Jul 26, 2011 | Price Pfister 15 Series, Bell Shower Head...
The moen adler tub/shower faucet came with a piping fixture that the hot and cold water come through and redirects water to the shower head. anyways, I have already replaced the tile in front of this. It...
They make face plates to cover up removal of faucets in tile. They are chrome and will fit any 6" single handle faucet cover plate.
They are used to cover up tile for removal of 8" spread faucets so you have a little room to move if you have to cut valve out and replace.
Lowes started carrying them and a plumbing supply house should have them if not email me and I will try to get you a address to get one if this will help you out.
They are about $15- $20 for it. Lowes carry them in NC .
Jun 11, 2010 | Home
Water leaks shere showerhead joins the shower stem
when reconnecting the shower head to the pipe coming from the wall..
did you use some pipe tape, pro dope or another type of joining compound?
this seems likely to be the problem.. if you don't have any on hand, visit a hardware store and ask their staff for pipe tape for plumbing and you should be pointed into the right direction.
May 12, 2010 | Water Pik & Wallmount Showerhead
I have a rubber expansion joint connecting the home sewar line to the public sewer line in my basement. I have expansive soils and in the 20 years that it's been in place the rubber expansion joint has...
It depends on the brand of the expansion joint you purchase. Ive found that they all differ in size and clamp location to some degree. So purchase the coupling first then measure the distance between clamps. Hope this helps.
May 09, 2010 | Plumbing
Leaking faucet
Most likely bad solder joint or leak where shower arm is screwed into fitting.
Sep 26, 2009 | Home
Walk in shower leak into room below
I would unscrew shower head pipe and either pipe dope it or tefilon the threads and then reinstall it. I would also take the handle(s) rosettes off and look for a leak from there with a flashlight, while shower is on. I believe the most comon leak for walk in showers are the door seals. Are you sure it is not coming out from under the door? Another test that yuo may want to preform is to Stopper the drain, fill the shower pan with water and watch for bubbles, or look for leaks from below.
Mar 20, 2009 | Home
Plumbing Logo
90 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
