Question about Sewing Machines
Needle position wheel jammed on Elna supermatic
  • 3 Answers
You might try Tri-flow superior lubricant. Take the lid off machine. put the oil on overnight - possibly use a little heat from a hair dryer. The ridges of the wheel can be pushed slightly with a screwdriver (at an angle on front of machine). I am working on one now.
Posted on Jan 31, 2010
  • Sewing Machines Master
  • 1,388 Answers
DO NOT TRY TO FORCE THIS If penetrating lubricant left overnight does nort resolve this, then live with it and.....Leave it alone.....it happens through lack of use and has become seized through electrolytic action of the steel and aluminium.
I had one in the workshop last week and when the wheel broke, that was the end, because it is the lynchpin to all other movement of the needle arm. To replace the plastic wheel requires that it move, so it is a hopeless scenario....just learn to live with the needle where it is and think about replacing the machine eventually, we all need to look forward to retirement.
Posted on Aug 02, 2009
My Elna Supermatic only sews on slow speed now. Why?
It appears to be an older mechanical machine. Has a thorough cleaning and oiling been performed on it? These old machines need frequent oiling with fresh good quality sewing machine oil to keep them running smoothly. The fact that it is slowing down, indicates to me that the old oil has solidified and is sticking things. Continued use in its present state could burn up the motor.
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Oct 23, 2016 | Elna Sewing Machines
Needle position wheel on Elna Super bought in 1969 won't move
I suspect your Super needs some degunking internally, the old dust,, fluff and oil dries up inside and goes hard and this can eventually gum up unused parts. You could take off the top and have a look, usually a couple of screws holding down the top blue cover. Use a cotton bud and denatured alcohol and clean up around the needle centring wheel internally, cleaning and some gentle movement may free it up. Mary, you may also like to join the Elna Heirlooms Yahoo Group, lots of Swiss Elna owners share their love and knowledge for these vintage machines.
Jul 21, 2012 | Elna Sewing Machines
Walking foot for 1963-1964 elna supermatic
try a elna dealer
sewingpartsonline.com
sew4less.com
May 15, 2012 | Elna Sewing Machines
Elna Supermatic- Ran briefly then No mechanical/needle motion however motor runs when switch operated.
Hello
If it sounds like it is grinding, take it back to where you purchased the machine from
Jul 12, 2011 | Elna Sewing Machines
Elna Supermatic 1960's/cream and blue. The machine is jammed. Hand wheel will turn backwards but not forward. I pulled some quilting thread out out the bobbin area, but didn't fix problem. ...
There may be threads jammed up in the bobbin holder area causing the jam. But removing the inner bobbin holder is a bit tricky if you haven't done it before. There are two little screws holding the silver inner down onto a black ceramic piece (inner guard ring), and you need to get these lined up the right way to get the bobbin holder back into position afterwards.
I would suggest that you join the Yahoo group Elna Heirlooms, then check out the files and photos loaded up by other members who work on their Elnas.
You shouldn't need to remove the feed dogs, just give them a clean with a little brush. But internally the machine may need a good clean and lube and without a service manual or good guide this can be challenging.
If you go this link http://www.arizonaexpressionz.com/elna_service_manuals.html you can down load the manual for this machine, the Star Series SU. Go to page 7 of the first part to see about removing the bobbin holder and inner guard ring.
It is a case of lining up the cut out of the black plate to the front, then putting the bobbin holder on top with the little arms facing front also, then replacing the two screws.
I'd suggest you take photos with a digital camera before you start to help you get it back in the right way.
I hope this helps you with the Supermatic, did you get the discs and accessories with it too? lovely Swiss quality machine with great stitching so if you can't get it unjammed, you may wish to find an experienced Elna Technician to take a look.
White Sewing Center stock lots of parts for these machines too, www.whitesewingcenter.com
Jun 08, 2011 | Elna 1010
The feed isn't working on my Elna
I'd suggest that you join the Yahoo user group for Heirloom Elnas, the members are very helpful and share images of manuals and their experience. You should be able to download a copy of the supermatic manual from here once you've joined up.
Is your supermatic a green model like this one?
or there is a white with blue top supermatic from the Star Series, it looks like this
If its the star series, you'll see above a round knob with red and black numbers, this is the stitch length dial. Red is reverse, black is forwards. The lever just to the left is the stitch width lever and the round dial to left again is the needle position dial.
If its the green model then the dials and knobs are in different places but they work in a similar fashion.
Good luck wiht your machine.l
Mar 04, 2010 | Elna 1010
Where do you oil a machine the bobbin winder runs fine but the needle mechanism will hardly run
I have a Elna Supermatic 1954 sewing machine. What is the proper way to upperthread?
Aug 25, 2009 | Elna Sewing Machines
Extra discs for an vintage Elna Supermatic plus pressor feet.
Try the usual eBay route, but also approach any Sewing Repair shop as they often acquire odd bits from old machines....We had 9 disks for a lady with an Elna SU only last week, all from a machine traded 2 years ago and really beyond resale.
Aug 02, 2009 | Sewing Machines
Have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Mar 11, 2009 | Elna 1010
Wheel on old Elna Supermatic sew machine does not move the needle
you can buy "horseshoe" clips. Push your wheel back into position and put your own clip on. Should be an easy fix.
Aug 02, 2017 | Sewing Machines
Sewing Machines Logo
112 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
