Question about Ricoh Aficio 450 Copier
My ricoh aficio mp3010 suddenly only gives my blanc copy's.( I allready changed the toner, but stil no succes. could someone please advise. thanks.
  • 162 Answers
It can be due to that the revealing unit is not working well, reviews the gears and if it has developer. Also to the transference unit it reviews the contacts.
Posted on Aug 31, 2009
  • Ricoh Master
  • 1,294 Answers
Your problems into the high voltage unit.Please check the carge corona (wire & holders&grid),inspect transfer bellt (under belt HV board,inspect and vacuum cleaning the toner and dust).Pull out the image unit ,rotary manual magnetic rolls to see a developer status,and reinstal the unit.
Posted on Aug 02, 2009
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
Error sc548 aficio 1022 ricoh
if the above solutions failed, ask a technician to clean the thermistors, as toner build up on them and then give you the same code, have also found that power surge or power failure also cuase this code to come up repeatedly
May 02, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio mp3010 ,i will change n?ew toner then againe coming add toner mesege,why
Have you replaced the developer yet???? It could also be the unit that the toner bottle goes into. There is a paddle wheel inside of it that move the toner and it may have broken up... Good Luck
Jan 15, 2013 | Ricoh AFICIO MP 3010 COPIER. REFURBISHED....
I am trying to find the drum, I have a line on my copies and would like to get rid of it.
The line is only in your copies?????
If so you problably have the mirror scanner durty.
Make a print and see if the line are stil there. If so, open the front door and next to the toner unit you will see the fotoconductor unit. inside you have the drum. I advise you to change not only the drum but also the blade.
Just make sure the line apaned also copy and print. If so you are right, the drum is faulty.
Good luke
Feb 21, 2011 | Ricoh Aficio 2022 Black and White Copier
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
My ricoh aficio mp3010 keeps comming up with error sc 548 any body now wat to do. please help me
You need acces service progpam:
1. Press the clear modes key.
2. Enter 1-0-7.
3. Press the clear/stop key for more than 3 seconds untill the service program menu appears om the touch pamel display.
4. Enter in the service menu.
5. Turn OFF the power switch,unpluged cords,wait 10 sec,plugged cords then turn ON power switch.
Aug 02, 2009 | Ricoh Aficio 450 Copier
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Jan 26, 2009 | Ricoh Aficio 450 Copier
Copies are half printed and half almost not printed (very lite)
If the copy count is around 150,000 or higher and you haven't replaced the developer as well, it should be replaced. That symptom can cause light copies if it hasn't been replaced every 150,000 cycles.
Aug 23, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh Aficio 450 Copier Logo
118 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
