Question about Jenn-Air JES8850 Electric Kitchen Range
I have jenn-air downdraft with a grease odor coming from it even when not in use.The smell is there from inside the cabinet housing the vent as well.Any suggestions as to cleaning?
Did you ever find a solution to the Jenn Air grease problem? We have the same problem with a grease smell.
Posted on Apr 18, 2010
My downdraft vent no longer removes cooking fumes and smells for days after cooking. We have changed the screens, but still have residue coming from the vent inside the cabinet. Does this vent need to
Remove the motor together with the blower wheel, go to the local self service car-wash and use the engine de-greaser cycle (if not available, buy a can at the auto supply, spray the fan blade and let sit for a while) and get all the grease of the fan blades. make sure the fan blades are cleaned thoroughly. the fan will now ran quietly and will remove all the grease away. in the future, clean the filters often.
Jan 06, 2014 | Kitchen Ranges
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
I used my grill for the first time, & the downdraft didn't work we'll, the house filled with smoke & eventually the downdraft shut off and I had to finish cooking in a pan. My Jenn-Air is...
The downdraft is electric so there must be something malfunctioning with it. It is a high volume downdraft fan that is to be vented to the outside. Could it be that something has clogged the vent hole up, not allowing the fan to evacuate the smoke?
While I am not a big fan of Jenn-Air, their fans are usually high quality if they are installed correctly, with the proper vent lines.
Jul 06, 2011 | Jenn-Air JGD8345 Gas Cooktop
Smelly Jenn-Air Refrigerator
some of the most elusive odors can be developed by a rotted piece of fruit,hidden behind drawers,or stowed away inside door shelving somewhere...to remove odors/take about 5-6 charcoal briquettes and wrap them in newspaper this will absorb odor,and yeah-it actually works leave them in for about 2 days
Mar 10, 2010 | Jenn-Air JSD2789GEW Side by Side...
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
I am wondering if with a Jenn Air downdraft electric range do I have to vent to the outside or does it recirculate? and is there a filter?
yes you have to or grease will build up under your house and I dont think there is a filter for this application but double check with a appliance supply house though I dont do alot of installs
Jan 10, 2009 | Kitchen Ranges
Outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Dec 08, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air Downdraft ducting roof Rack w/flapper
go to www.luxurymetals.com
there are many good high quality vents on the site
Oct 08, 2008 | Jenn-Air HV363 Kitchen Hood
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air JES8850 Electric Kitchen Range Logo
838 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
