Question about Boating
1996 mecury outboard, was running fine & just cut off, later it started & ran fine then when i shut off it would not start ? When I returned home i hooked the water hose to it , it started up right away ran for 20 seconds then cut off again.
  • 3 more comments
  • carolinacoon Aug 02, 2009
    Thanks canbruce 75
    I changed the primer bulb, fuel filter & the spark plugs, has good fuel flow from the fuel pump but still will not start,it is a 1996 90 hp mercury
    Canbruce
    No no fire at the plugs
    Hey Canbruce
    As a matter of fack the prop did hit a few rocks , we were in very shallow water & had the motor kicked up high just idleing along for a long time when it cut off, do you think that is part of my problem??
    Canbruce 75
    By the way did you catch anything today??
  • carolinacoon Aug 09, 2009
    Hello Canbruce 75
    Just wanted to thank you for all the help , I got the motor fixed for 500.00 dollars , it was the statter that was bad it's at the top of the engine where the flywheel is , so im ready to go now just broke thats all ha ha , thanks again...
    President:
  • 1,776 Answers
I don't know what horsepower the motor is, but if you are using an external fuel tank with the hose and primer bulb, then I would look at the bulb as being defective. I have an old 7.5 horse Sears motor and had a similar problem. I could get it to start but not stay running and the problem was in the primer bulb. It would shut my gas flow off. I replaced the hose and bulb on the tank and it resolved my issue. Hope this helped and best wishes.
Posted on Aug 02, 2009
  • 3 more comments
  • Bruce Canfield
    Bruce Canfield Aug 02, 2009
    Do you have good spark at the plugs?
  • Bruce Canfield
    Sorry for the delay in getting back to you. I absolutely had to go fishing today. I am not as familiar with these motors, but I would look at a faulty coil/coil pack (if so equipped) since there is no spark. The prop didn't hit any hard objects just before you started experiencing this problem, did it?
  • Bruce Canfield
    Yes. I think that the key was sheared off in the flywheel. The key is made of soft metal for just this reason, so that it will fail before damage is done to the crankshaft. If the key is sheared, then you won't get spark, even from a good coil. I don't know if that is the problem, but I would consider it. That's why I asked about whether the prop hit a hard object.
  • Bruce Canfield
    Thanks for asking! I caught a couple of nice bass. One went about 3 1/2 pounds and I caught one nice striper. Not as big, but quite a fighter.
  • Bruce Canfield
    Bruce Canfield Aug 09, 2009
    Sorry for the cost, but I'm glad that you got the problem lined out!. Good luck with the boating and fishing! Have a good one and best wishes.
Starts up, then why does it cut out when going to full throttle?
possibly overheating try running slower which creates less heat
Oct 25, 2015 | Yamaha Tilt Trim Motor, 115-225 HP...
1996 deville runs then doesn't?
You need to find out what is missing when it won't start , spark - ignition system or fuel pressure . No Start Diagnostic Basics EricTheCarGuy
Apr 18, 2017 | 1996 Cadillac DeVille
1996 Suzuki DT30C outboard- won`t start. I installed a starter last week. It ran great. Now it won`t even cough, nothing. I pulled out the kill switch & cheked, it has connectivity.
Check for compression. If it has fuel and spark and compression it should fire. If the compression is low it will not run.
Apr 17, 2012 | Motorcycles
30 horse power '88 Mariner motor won't stay started
If you have portable tanks, some have screens under the coupler assembly. They could be dirty. If you have more than one tank, you could switch out on the water. Make sure the bubble pump is hard and full of gas. It is not uncommon for some outboards to need choking to start even when warm. This is an updraft carburetor characteristic.
Jun 24, 2009 | Light Outboard Motor Boat Bass Fishing...
1996 9000 CS will not start
try adding some HEET to it it is a gas line antifreeze product which also takes care of water in the gas other then that you may need a fuel pump which will require a towe
Oct 24, 2008 | 1996 Saab 9000
Won't start
these early injectors its more likely the prblem try some chevron injector cleanor see if starts running better if it does and returns ur injectors probrably need replace go rockauto.com if they do theyre cheap
Jun 02, 2008 | 1991 Pontiac Grand Prix
Boating Logo
233 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
