Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Fl 2 code. replaced flame sensor and still get same error code and heater will not burn for more than 30 seconds. Problem arose after pump was plugged back in while heater switch was still on.--jjc
    Champion:
  • 246 Answers
Need two parts ignator kit and flame sensor kit
Posted on Aug 19, 2009
My heater lights but turns off in a few seconds. error code ID
Just an idea, the gas goes bad in the line if the heater has been unused for a few months, I bleed the line at the valve. this is a common problem with motorhomes.
the pilot lights, but the gas is weak and doesn't burn hot enough to tell the thermistor / thermocouple or the (bulb) there is a flame.
OR check to see the flame is hitting the bulb, it might have got bumped during cleaning.
but if the unit just up and quit, the thermocouple might have gone bad, and need replacing, and on some units can be a cheap easy fix.
Hope I was of some help, and please get back to me with The Fix..
Your local pool pump repair guy longwood Fl
Aug 20, 2015 | Hayward Pool & Spa
Why do I get FL 3 error code?
if new heater and wired 120 volt try reversing the balck and white wires sounds like not showing rectification if old heater bad pcb board
Jul 11, 2014 | Jandy Lite2 Heater LJ175P - 175,000 BTU LP
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
I am getting an FL 2 error code on my jandy lite2. I changed the flame sensor and still get same error message
Look at the list of codes inside the cover of the heater. Your owners manual should have a complete remede for all codes.
May 27, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Error code fl
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$!##!
May 14, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't drain..like filter is clogged
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@#$
Mar 27, 2010 | Kenmore Elite 21082
Model 110.21062 calypso drain issues
Flood Condition:
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 27, 2010 | Kenmore Elite 45986 Front Load Washer
What is error code flashing Fl represent? Can you just fill the tub with water from an external source and expect the machine to go into wash cycle by preesing start? Does the tub have to fill throug pump...
Flood Condition:
Jan 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code and 1" of water won't drain
Every time mine does this it has strings stuck in the pump. Remove the pump and either take it apart on puld the junk out of it it or do what I did and go to FirstSource pay 10% for a life time waranty and buy a new pump. I've replace it about once a year. Check the seal around the swashplate in the bottom of the drum it may need to be replaced along with the u-joint. If this is worn it allows more **** to be sucked into the pump. I never buy whirlpool again. I have 2 appliances that give me constant grieve a whirlpool flame lock water heater and this expensive piece of junk.
Aug 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
406 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
