Question about Epson Stylus Photo 2100 InkJet Printer
We are setting up new TallyGenicom LA800. However, printout has dot or period in between each characters printed. Hence, a single row info is printed on two rows. What seems to be the problem?
    Novelist:
  • 169 Answers
It would be strange for the printer to print dot between each printed character without this coming from the system.
As a check the first thing I would recomend doing would be to print a self test print on the printer, you can do this easiest by printing a menu print.
To print a menu print put the pritner OFFLINE
Press SETUP
Press the button under MENU
Press the button under PRINT.
The printer should print out its configuration page, if this has dots between each character then this defiantly means you have printer problems.
You can try defaulting the pritner back to factory settings, this is down by holding down the four buttons (1, 2, 3 & 4) under the LCD display whilst powerind the printer on.
If the menu prints OK, then there is some sort of other strange system or communication problem.
If the pritner is connected via serial, check the serial settings on the pritner also chack the pin configuration of the connector used to print to the printer.
Try printing from another system or application to identify what might be causing the problem for example an application or driver problem, perhaps try printing from a PC directly to the pritner to check the interface on the printer is OK.
Check the emulation setting on the pritner ensure this is correct.
Posted on Sep 21, 2009
How to color a cell/s but will not appear on a printout
What exactly is your end goal? If you want to have some info in cells without having that printed out, you can "set print area". If you want to have info that you can see in excel but not have it show up in printout, perhaps you can hide columns or rows. Or you can color the text of your cells white and they will be invisible until you color them black again.
Mar 31, 2011 | Microsoft Windows XP Professional
The print job for the TallyGenicom 6312 is a coupon and has a barcode in it, and the barcode is not readable by the barcode reader. The printed barcode looks perfect. And, the barcode reader has no...
Try to adjust the "Bar" setting in the Graphics menu. Here you can specify the density of the barcode. I have seen the best results using the Medium setting.
Jul 12, 2010 | TallyGenicom 6312 Matrix Printer
Unwanted 'dots' on printout
There is a dot somewhere on the drum, remove the drum and toner cartridge from the machine, then remove toner from drum. Look at the shiny roll, you can turn it from the black gear on the side. Once you find the dot use a cue tip dipped into little bit of alcohol and clean it off.
Mar 31, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do i clean the print head to a good printout
This is a Thermal Printer, which means it uses tiny hot wires to create dots on special paper to form the characters. There may be little to nothing you can do to make output better. You can try unplugging the unit from the power source and using a cotton swab dipped in alcohol to clean any paper fibers or residue from the face of the print head. More likely than not however is the possibility that you will have to have the print head replaced in order to restore crisp printouts. These print heads, much like the older dot-matrix print heads, have a limited lifetime because of the way they function.
Nov 20, 2009 | Printronix T5000 Thermal Printer
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
I have a tally t2265. when i switch it on it comes up with "hardware error". Please help Don
9 out of 10 times this error is caused by the print head assembly binding up on the platen (the metal bar that the print head moves back and forth on). Remove the ribbon and paper from the printer. Wrap a thin cloth or Kimwipe around the platen and spay some WD-40 on the cloth. Work the cloth back and forth on the platen to clean it. Then with the platen still damp with WD-40 work the print head assembly from side to side, this will clean out the inside of the print head assembly. Clean the platen one more time.
I have seen this problem caused by two other things, a defective ribbon casette or worn out drive gears.
Dec 01, 2008 | TallyGenicom (048959) for T2265, T2280,...
TallyT2240 Dot Matrix only prints the middle part of the caracters
It sounds like you have one of two problems;
1) The ribbon cartrige it warn out or damaged, leading to no ink in a particular area.
More likely
2) The print head is damaged or warn out or is not connected correctly to the pritner. The print head may need to be reseated or if this does not fix the problem the print head may need to be replaced.
Oct 28, 2008 | TallyGenicom TallyT2240 Dot Matrix...
Unrequested characters and nos on top of printed matter
you can try with epson compatibel 9pin from the printer list
Jun 28, 2008 | Epson Dot Matrix LX-300+ II Printer
Epson Stylus Photo 2100 InkJet Printer Logo
166 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
