Question about Garden
Runs well untill it gets hot. then cuts out
It starts fine. It's a Homelite chain saw 14 inch. As soon as it warms up or there is a load aplied it starts to lose power and cut out.
  • tomstaxiderm May 11, 2010
    When u say it starts to lose power does it sound like like it is trying to work hard before cutting out.
    Scholar:
  • 135 Answers
If it's the little xl model, it's probably the ignition coil breaking down when it gets hot and therefore it can't and won't be able to handle a load. Also, scarred pistons skirt or rings could also be some of the problem here. Make sure your mix for a Homelite saw is 40:1 not 50:1 like most saws are. Homelite seems to run better with a heavier oil mixture. Good luck.
Posted on Aug 02, 2009
16 inch poulan chainsaw got hot and started to smoke and now the recoil no longer works. I took the cover off and there is two springs that seem sprung. should I toss it and forget it or this something I...
how old is the polan 16 inch is it a solid body saw or does it have anti vibration handles, so your hands dont go numb after cutting for 15 minutes.reason i asked is: you can buy a brand new reconditioned homelite with anti vibration handle for 85.00&shiping.
at the very least,your polan needs the recoil starter fixed
and that does not address why the poulan got hot & started to smoke.
For the problems you described , at least $100.00 labor plus parts to fix at a chain saw shop
It might barely be worth it if you were a do it yourselfer and wanted to try to fix it.
if you dont want to be a diy chain saw mechanic, sell your polan for parts for $20.00 on ebay and buy a new homelite
16 inch 38 cc with anti vibration handle ,so you can cut for 6 hours straight, if need be. You get a reconditioned saw that is ready to go and a 90 day warranty. or buy the saw brand new for $110.00 and free shipping@ amazon.com
Oct 07, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
My Homelite ZR10926 16-Inch 33cc Ranger it is starting, idling, it dies when I accelerate it. I assume is the carburetor, maybe ? thank you.
It probably is not getting enough fuel. Check the filter in the tank. If it has been sitting with stale gass this filter plugs up.
Try running the engine with some choke. If this helps, try adjusting the carburetor high speed screw.
Jun 04, 2011 | Homelite ZR10926 16 Chain Saw
I HAVE A HOMELITE XL2 CHAINSAW WITH A 12 INCH BAR, CAN I INCREASE THE BAR TO A 14 OR 16 INCH BAR.
Usually, yes. Take the saw to a service dealer who can fit a longer bar and proper length chain. You will need to keep the chain properly sharpened and adjusted to prevent extra load on the engine. Hope this helps!
Aug 16, 2010 | Oregon Scientific Oregon Bar And Chain Set...
Homelite Super XL running very hot. Is this the carburator?
Hot running saws are either in need of cleaning the engine and inner case of accumulated sawdust and dirt with compressed air, or the engine is running lean which will result in severe engine damage if allowed to continue. Check the air cleaner, fuel filter, and muffler for any plugging. Check the fuel lines for decay of any kind. Make sure the chain is being properly lubricated and sharpened. Check the carburetor fasteners for tightness including those mounting it to the engine. Remove the spark plug and look for a light to medium tan color on the inner insulator. If burning white, it is not getting enough fuel. Have the two jet screws been adjusted? If so, turn both screws to CW stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on. Adjust H CW until the engine starts to speed up, but continues to 4-stroke. Proper adjustment is 4-stroking at speed, but immediately 2-strokes when cutting. This produces best power and least heat. Allow to idle and adjust L CW until the engine runs fairly well, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning , but the engine continues to run. Check chain oiling by holding the bar tip near a piece of cardboard and run the engine fast for couple of moments--the chain should throw off a thin line of oil. Hope some of this helps!
May 11, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Hi how to tune homelite 330 chain saw carby, idle
Before adjusting anything, check the fuel filter, air filter, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Tighten all carburetor fasteners. Make sure you have fresh fuel mix in the tank. Does the primer bulb pull fresh fuel into itself when pumped? Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and should allow the engine to start and run. Start the engine and allow it to warm up, then pull the throttle full on. Adjust H needle CW until the engine starts to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for fairly good idle, but still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 09, 2010 | Homelite ZR10926 16" Chain Saw
Bought a new UT10520 in 46cc Homelite Chain saw last year and it did not run well out of the box. It would die or hesitate when going full trottle. I was parallel cutting a large log. I adjusted the L...
You should have taken advantage of the warranty when you first noticed the problem. Go to: http://www.drystacked.com for an excellent 12 page article on Walbro carburetors--theory and troubleshooting. Note carefully, the caution about the lower chamber gasket and diaphragm positions. Hot running engines imply very lean fuel conditions. Hopefully, you haven't damaged the inner cylinder liner/piston/rings due to excess heat and lack of lubrication. At 50:1 fuel ratio, there isn't much lubrication to spare. Make sure the carburetor fasteners are tight and no plugging of the fuel filter. The head and cylinder are one casting--no head gasket. Try turning both jet screws CW to the stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on--adjust H needle CW until the engine speeds up, but continues to 4-stroke. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces the most power and least heat. Allow to idle and adjust L CW until the engine runs fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw to stop the chain from turning, but keeps the engine running. Hope this helps!
May 07, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
PETROL ENGINE WORKS FINE BUT SAW CHAIN DOES NOT FU DOES NOT DRIVE
It is possible that the clutch has froze, could try taking the side pannel of and seeing if it spins freely with out the chain bar on. If it does, it could be a problem with the chain, make sure its not tightened up too tight and that the chain can move freely over the bar.
Jan 10, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
My chain saw (14 inch gas powered) would not
Modern chainsaws have the ability to run without turning the chain via the chain-brake. To set the brake the uppermost handle is pushed forward (toward the chain) and a firm snap should be heard and felt. To release the brake you pull the same handle back (towards the engine) and get the same "snap".
Concerning oil leakage: Bar/chain lube collects on the inside of the clutch cover and the sawdust mixes with it as you saw. A surprising amount of oil gets absorbed in the sawdust and later seeps back out when the saw is at rest. If the level of oil in the tank noticably drops after sitting overnight you may have a leak...otherwise it's normal.
As for a running chain that wont cut, it is common for chains to be installed backward and the unit still function perfectly (it just won't cut wood). See the proper chain orientation here. In this photo the chain travel is from left to right.
Sep 26, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Garden Logo
262 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
