Question about Vacuums
Will Sebo K1 blow as well as ****?
I have a sebo K1 komfort. Will it blow as well as ****? If so how? I've lost the manual!
    President:
  • 389 Answers
Sorry, but the answer is - no, it won't!
Posted on Aug 02, 2009
Hi, I've just had my Sebo X4 back from being repaired (motor was growling so Sebo replaced it FOC under warranty) however, the replacement motor is 1000 watts. I queried this with Sebo, as they c
Watt= volts x amps So what are you losing? Not much really. Should they replace it with the same motor? Possibly, but you got a free motor out of them. To be honest I think you're splitting hairs on this one. The difference in how much cleaning that sebo will do with one motor vs the other is beyond minimal. The aggressive brushes on that vacuum do 95% of the carpet cleaning and both motors will have no problem turning it at sufficient speed. As far as suction goes I'd be amazed if it was even a noticeable difference. That's an amazing vacuum you bought, I wouldn't worry about it and go on with life.
Good Luck
The Vac Dr.
Nov 12, 2012 | Sebo X4 Bagged Upright Vacuum
Changing sebo telescopic slide button, how to
go to :http://www.sebo.co.uk/support/downloads/
download your instruction manual, and proceed according with common sense forchange your parts.
God bless you
Jul 15, 2012 | Vacuums
THE BRUSH ON MY HEAD FOR THE SEBO K1 HAS STOPPED SPINNING WHY???
Check the brush roller at each side to see if threads are wound around it. Also, check the brush to see if there are threads wound around it. This is what generally stops the brushes from spinning. It will take sometime to unwind the threads/lint and you may need scissors and tweezers to fully remove all of them but it will be worth it!
Nov 01, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
How to fix sebo air belt k1 hoover
what is the problem first, I need to know before I can help
Jul 29, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
Taking off the bumper from A Sebo K1 Airbelt
First, remove the clip at the back of the machine where the airbelt joins (lever it off carefully with a screwdriver). The airbelt is in two parts - the bulky foam strip and a thin material cover. The cover is held in grooves, top and bottom, running all the way round the machine, by two thin plastic strips around which it is wrapped and which just slip into those grooves. The challenge is to get those strips, and the covering material, out without damaging them. Just prise one end out with a small screwdriver and work your way around the machine - it's more a matter of patience than anything else.
Apr 10, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
My Sebo AirBelt K1 just stopped working
I work with a Sebo dealer (in the UK), where we repair all makes of vacuum cleaner. It's testimony to the quality of Sebos that in several years I've only had one of this model to repair (so my memory is somewhat sketchy). However, from first principles, the finger of suspicion points to two likely causes of this problem. First, the copper wire may have broken within the flex - this commonly happens where the flex is subject to both stress and tight bending, which is the two extremities (where the flex enters the plug, and where the flex joins the rewind reel). You will need a continuity tester of some kind to check this, of course. The flex may be visibly damaged, but often there's nothing visible externally. Second possibility is that one or both of the motor's carbon brushes is worn out. You will need to get them off the motor to check. Check both - they can sometimes wear very unequally - a new one will have about 2cm of carbon exposable, whereas a worn one can have nothing left at all. As for what's economically replaceable... it depends what you can do for yourself. In the UK a new flex complete with rewind reel will set you back about £45. However, it is possible just to wire in a length of new flex provided you make sure that any connection you make is good, safe and not subject to stress from winding and unwinding. As for the carbon brushes, in the UK they are about £5 each. For a complete new motor you'll not get much change from £100.
I hope this helps. If you need me to try again just post a reply, giving any more information you can, and I'll see what I can do. Good luck!
Jan 13, 2010 | Sebo K1 airbelt Bagged Canister Vacuum
No power
This is a dead motor. the electrical motor is experiencing windings failure and will have to be replaced or rebuilt. Just to be safe, remove the switch and test with voltage needle to see if the problems here. i suspect total motor failure.
Mar 01, 2009 | Sebo K1 airbelt Bagged Canister Vacuum
Sebo Airbelt K1 Electrical Problem
Remove the belt or seal that goes around it, there are some clips to take out, then it will separate.
Mar 03, 2008 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Sebo airbelt k1
No screws under the castors. There is 3 case clips, the bumper hides them, maybe this picture will help:
Feb 06, 2008 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Sebo K 3 Vacuum
I had a problem with my K1 Komfort model which sounds similar to this. I initially thought the cord was too short but the machine wouldn't give out anymore and retracting was difficult. A Sebo engineer/helpline told me to pull roughly on the cord, of which I did and was rewarded with 2 metres more than what I thought I didnt have! So, perhaps if your machine isn't retracting properly, give the cord a rough pull with gloves on, or a strong grip - the cables on the K series are notorious for stopping up. Afterwards wipe the entire cord down with furniture polish; it will retract much more quickly.
Feb 21, 2007 | Sebo Air Belt C3.1 Bagged Canister Vacuum
Vacuums Logo
54 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
