Question about Sony FD Trinitron WEGA KV-27HS420 27" TV
2002 27" SONY Trinitron. Half-screen picture with bright line.
I was playing a video game this morning, and I believe I heard a small "pop" as half of my picture went away. It appears as though the top 45% of the picture has been condensed to a thin bright line, while the bottom portion of the image is fine. There is no additional deforming of the image, and no discoloration. All 4 inputs on the back of the TV are occupied - the problem is not input-specific. The set is out of warranty. Just curious about whether there is an easy fix. Details would be nice, or recommendations (although I was already considering purchasing a new TV, so that recommendation is not necessary). I will continue to check the site for updates. Thanks.
  • Sony Master
  • 8,457 Answers
Ur video board have burn capacitor,check the board connect to the CRT board connected to the tv tube.
Posted on Sep 09, 2009
Only half rca tv screen shows up
I think you may have a tv tube problem...
Jan 26, 2014 | Televison & Video
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
May 01, 2012 | Televison & Video
Problem after replacing PSP screen
try to replace the screen on the store where you bought it. they'll replace it immediately
Mar 06, 2010 | Sony PlayStation Portable (PSP) Console
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony Trinitron wega KV27FV310
Sounds like a problem with the vertical circuit. If yuo can solder and are comfortable with working inside the set, you may be able to repair this.
Keep us posted.
Dan
May 23, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
White horizontal, zig-zagging lines
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Top half of screen is dead
HEY WEGA-YOUR SET HAS A BAD VERTICAL OUT IC AND ANYTV GUY CAN REPAIR THAT FOR A REASONABLE (COMPARED TO REPLACEMENT OFSET) COST.JOE TV
Nov 20, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron KV-32S40 32" TV problem
This is a simple and common problem. The solder joints on the vertical output IC have cracked loose. I actually did a housecall on the exact same set with the exact same symptoms this morning! A good tech will resolder the pins of the vertical output IC and all other major solder joints on the main board and the set will play fine.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Solid green screen
Is the green really bright with small white lines in the screen?? If it is its probably a shorted picture tube. That is if you still have sound. If you have no sound its probably a power supply problem in the sweep section of the set. This is not a repair for a consumer to do as its a solid state set and there are no user serviceable parts inside these sets. Get a service person to assit you with this repair. Good Luck
Jul 01, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
SONY KV-27FV310: UPPER HALF OF SCREEN IS BLACK
You have a vert sweep problem and unless you know how to trouble shoot this cuircit bring it to a pro. I found out mostly in these sets that the vert output IC is bad.. Also sometimes the b+ filter cap off the fly is leaky and made the IC to fail. Another thing is Im surprised to hear you got a pic with the vert failure and a bright line in the pic!! This could be a big problem when the sets fixed so dont run it too long like this. It could burn a line all the way across the screen and you will see a dark faint line in your pic because of this. BE CAREFULL!!
Mar 25, 2006 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Sony FD Trinitron WEGA KV-27HS420 27" TV Logo
121 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
