Question about Maytag Bravos MTW6600T Top Load Washer
We have well water w/sediment filter. soap in dishwasher and washing machine does not dissolve. washing machine has heavy build-up around rim after only a few wahings.
    Problem Solver:
  • 9 Answers
Get water tested,sounds hard,filter doesn't solve,test before invest, get 2-3 reputable solutions,they will be salesmen,u may simply need softner or could be more difficulty such as iron,etc
Posted on Aug 02, 2009
I have a Bosch dishwasher. I am getting a very large build up of crust on all the parts to the point that it clogs up and won't drain. This white build up is so thick at places it is past like. Help!
Dishwashers do not drain a such. The water has to be pumped out so it important that you don't do anything that will interfere with the efficient operation of the pump.
1. You need to pull every movable item out of the washer (baskets and the water filter units at the bottom of the washer) and give them a good clean. Then clean as much of the white gunk you can out of the machine. This is a build up of soap residue and may include undissolved soap.
2. Then run the machine while empty through 2 complete wash cycles with maximum hot water temperature to clean what remains out of it. Do NOT use any dishwasher powder while you are doing this.
3. The problem you have can be due to
- poor quality dishwasher soap powder being used or soap products completely unsuitable for dishwashers are being used
- too much soap powder product is being used
- the water temperature in the machine is far too low. In that event the water heater unit in the machine may be faulty.
Whatever dishwasher powder you are using I would change and buy a better one and also use less than what you have been using in each wash up to now. I would also STOP the machine in the middle of the wash cycle, then open the door and check the water temperature. It should be so hot a wall of steam should rush out when you open the door.
Jan 02, 2016 | Bosch Dishwashers
Soap remains on the dishes after the wash cycle is complete.
Check that the holes in the spray arms haven't blocked up and the filters in the bottom are clean. The arms may not be rotating. To check this, when the machine is washing, open the door, turn all the spray arms to face the same direction, shut the door and leave running for about 30 seconds. Open the door again and look at the position of the spray arms. They should have moved.
Nov 25, 2013 | Samsung DMT400RHS Builtin Dishwasher
The soap holder is opening during the wash cycle but the soap tablet is not dissolving. Any ideas?
Is the water coming on? Is water hot enough? Is washer overloaded, water jets aren't hitting the soap? Maybe try a different brand of soap tablet? Run the dishwasher in "heavy soil" mode which will use hotter water and run for longer?
Nov 20, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
The dish washing powder does not wash out completely unless the machine is set to heavy duty only. we will often open the machine at the end of a wash cycle and see the soap powder all wet and soft but not...
Seems to be problem with spray arm pressure. Check the spray
arm jet nozzles.
Check the incoming water flow to the machine. clean the strainer fitted at the washing machine end connection.
Being in the extended warranty, take the help from
the service provider.
Aug 31, 2010 | Dishwashers
Our kenmore dishwasher has calcium deposits all inside it, how can I get them to dissolve?
use a water sediment filter that will handle the hot water capacity needed for the unit during a washing/rinse cycle of the dishwasher
Jul 25, 2010 | Kenmore Dishwashers
GE Portable Dishwasher won't fill/cycle
In a front corner of the tub is a float switch that raises up as the machine fills, then shuts the water off. when pumping water out the float drops and enables the fill solenoid valve to work when signaled by the timer circuit. Make sure the float is free to rise and fall. The residual soap may be holding the float up. Run some cycles without soap to clean the tub, manually clean it out if necessary. Make sure the water supplied to the machine is at least 129 degrees to get good cleaning and prevent soap build-up.
Sep 04, 2017 | GE 24-7/8" Convertible Portable Dishwasher...
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Water is not circulating. machine runs full cycle but when opened, soap is in a mushy lump, not dispersed or dissolve, and dishes are still soiled
When was the last time you cleaned you drain filter? That should be done routinely .. If that's clogged then the the sediment from other cycles just gets redistributed on your dishes.. You might also check the washing arm that spins for debris or clogs.. Try cycling it without any dishes a few times to see if all the water drains out after a cycle.. That will help you identify if its a drain problem or if the system needs other service.. Hope that helps !
Aug 18, 2008 | Frigidaire Dishwashers
Bosch dishwasher problems
the is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Mar 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool gold dishwasher leaves film on dishes
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
Feb 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Maytag Bravos MTW6600T Top Load Washer Logo
54 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
