Question about Sony Cyber-Shot DSC-P52 Digital Camera
Cybershot 3.2 seems to work fine until you push button to take photo
Strange things just started happening. Everything is normal until you depress the button for picture. In camera mode, the initial depression gives the auto focus, but then you can't take a photo. It does nothing. In night time or Movie/mpeg mode you can't depress button at all. Have had this camera for over 3 years and never a problem.
Re: Cybershot 3.2 seems to work fine until you push...
When i turn the camera on it says turn the power of and on again and the lens cover will not open
Posted on Jan 19, 2008
0 characters
3 Points
Sony Cybershot DSC-N2: shutter button not working
poor contact in the circuit under the button. you may need to replace the circuit. contact sony and ask for the part number
Jan 05, 2014 | Sony Cyber-shot DSC-N2 Digital Camera
It turns on but won't take a picture when you push the button! I downloaded the pictures on the card because I was told maybe it wouldn't worked due to a full card. It did have 2300+ photos, but only 77...
The shutter button has a little nib on its end that can break off with age. This tiny piece of plastic extension is needed to fully depress the shutter switch inside the camera. There's a fellow on ebay that sells these with instructions (see this link). But sometimes you can get a better deal by buying a broken A520 with other issues, and just cannabalizing this part.
May 09, 2010 | Canon PowerShot A520 Digital Camera
Sony cybershot pictures fracture when stored on computer
So you mean that when the photos were transferred to the computer, they were fine and now after few months the images on computer are corrupt .. Right?
If that is the matter then I feel that its not a problem with the camera .. It should be some (strange) problem with the storage device on which you copied the photos to.
May I look at a sample image please?
Apr 02, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Sony cybershot DSC W30 buttons fail
take the battery out and let the camera sit for an hour or two, take out the memory card, try to view photos on computer, if it does not work, you will have to format the card and start over. Some times when the format on the card is bad, the camera will not work properly. I have two cybershots myself.
Mar 13, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Cannon G7 need help
Had the same problem a few months ago.There was a high pitchedwhisltle and I think the screen said "lens fault.turn off camera" or something similar.Bought a G9 to replace as the 7 was out of guarantee but sent the 9 back to the e-bay reseller as it was obviously secondhand with grit around the lens ring and the viewfinder.Ebay never again!.So 3 months ago ago I tried the G7 again with a fresh charged battery before I consigned the camera to the loft.I noticed that each time i switched on the whistle and message was there but the lens extended slightly further each timeso I kept rebooting until the lens was fully extended.Turned the camera off and on again and everything was back to normal.It seems that this may be Canons protocol when a camera goes back.Its been absolutely fine until today.It wont boot up at all.I have tried 2 fresh charged batteries and its dead.Any ideas anyone?
Nov 06, 2008 | Canon PowerShot G7 Digital Camera
Menu Problem
Did you try calling Canon tech support or returning to retailer if the camera is really not functioning properly this soon after purchase, I'd try returning it once all troubleshooting issues have not resolved the issue.
Hope this helps!
Feb 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
The flash circuit has gone out the squilling noise is the flash compasitor popped and the acid inside is burning.
Feb 14, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
i think the firmware is corrupted ..... you must install new firmware ....
just visit the nearby showroom or technician he will install the new firmware ..........
for installing firmware it may costs some 300 to 400 bugs ....
how ever there may be other problems too may be the battery is dead just change battery and check....
check whether it is detecting in pc or not..........
Feb 11, 2008 | Digital Cameras
My Sony Cybershot DSC-S45
the button is offset inside the camera, there is a little piece of plastic that seems to loose its elasticity and will not depress the actual on/off switch inside.
Dec 09, 2007 | Canon PowerShot A460 Digital Camera
Camera keeps resetting the settings when turned off
Possible solution?
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
77 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
