Question about Frigidaire FEF364DQ Electric Kitchen Range
Replacement of kenmore brokenglasstop on range model 79096212400
Have to replace the glass top-maintop assembly on Kenmore model790.96212400..canning vegetables and jar slipped and broke glass majorly w/hole and major run up the middle.Found the part on www.sears.com to order directly#316420733 yet manufacturer is replacing with #316456256,Canot find installation instructions for this assembly, yet have the repair parts list from sears. Any ideas how to install, unsure of bolts/brackets that may be involved & don't want to disconnect before full knowledge of project. Of course, power to unit will be cut off before installation. I'm quite handy, yet unsure of what may be connected to the top from underneath. Appreciate all help. Really don't want to call service if this is not a tough job to do Thanks all
2 Suggested Answers
SOURCE: How to replace maintop (cooktop) frigidaire oven FGFG79GBA
To remove the main top first remove the grates,
burner caps and burners. Using a ¼” socket
wrench or nut driver remove the mounting
screws at each burner orifice assembly.
Insert a putty knife or similar tool between the
main top and manifold panel near the outside
of the front corner. Push the putty knife toward
the rear to release the maintop mounting clip.
Repeat for both sides.
When the mounting clips are released the front
edge of the cooktop can be lifted. Make sure
that the orifice assembly does not bind in the
cooktop when raising the top to remove it from
the range.
Lift the front of the cooktop and pull forward to
disengage the back edge from the rear hinge
bracket. The cooktop can now be replaced by
reversing the previous steps.
See Manual at http://www.electroluxtopservicelatam.com/image/Manuals/Services%20Manuals/Preparation/Cooking/30%20Inch%20Freestanding%20Gas%20Ranges%20(5995440277).pdf
Posted on Jan 23, 2009
Kenmore stove model number 970C60323 with broken glass top unable to find part number can someone help me out
Most times, the glass tops are more costly than a whole new range. Depending on the AGE of this range, consider a new one or have a professional replace the top. Time is wasting!
Dec 17, 2014 | Kenmore Kitchen Ranges
Replacing the ceran glass maintop
Actually if you've removed the 2 or 3 screws at the front (underside) of the cooktop, you can lift up the front. Prop it up with a board, and then remove the 4 screws that hold the 2 brackets that hold the 4 elements to the cooktop. Now pull the cooktop forward a bit, and you should see a green ground wire attached to the back of the cooktop. If not, then don't worry about it! Just pull that cooktop up and off the range. You will need to transfer the 2 tabs in the back of the cooktop, and the silver steel bar located at the front of the top to the new cooktop. Then reverse the process to install the new cooktop and re-fasten the elements to it.
Apr 22, 2014 | Kenmore Microwave Ovens
Between glass dirty on kenmore glass top range
the door must be removed from the oven and taken apart
Oct 23, 2011 | Kitchen Ranges
I need help to replace the glass smooth top for kenmore model number 7909621340B. Can someone please help.
you can get the replacement top here
appliance parts solutions have the part# you need if you dont find it in the search call...good luck
Feb 09, 2010 | GE Spectra JBP78 Electric Kitchen Range
Can I replace the glass stove top on my Kenmore Range????
Yes! check at repairclinic.com you can find parts for your appliance. be sure to have your model number handy.
Jun 06, 2009 | Kenmore Kitchen Ranges
Kenmore inner oven glass cracked (911.93411002
I suggest you check www.repairclinic.com
They will answer your questions and may even have a better price on the replacement glass.
I have no affiliation, but have been pleased with their service.
Mar 20, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
the range.
Dec 16, 2008 | Frigidaire FGF316 Gas Kitchen Range
Frigidaire FEF364DQ Electric Kitchen Range Logo
205 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
