Question about McCulloch FH160G Pressure Washer
When the washer is fitted up ready to use the water comes through the handle ,i took the end piece off ,the water then comes through to where the end piece fitted on,when i looked through the end piece i can see straight through so it doesnt seem to be blocked with dirt ect
    Problem Solver:
  • 7 Answers
Check o rings washers
Posted on Aug 02, 2009
I have a pro 1600pwa no22049022491 and it leaks from the gun i took gun apart to find that the small tube comes up the handle inside bends then gos on the end of the trigger in the bend ther is a small...
No parts for the gun. I'm not sure what model you have for sure, I don't recognize 1600 PWA, see link.
http://www.ppe-pressure-washer-parts.com/job-mate-1600-power-washer-parts
Apr 19, 2014 | Garden
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
My Snap-On 2000 PSI pressure washer is leaking through the trigger handle. I have no pressure coming out of the wand but the motor runs.
The fitting for the trigger is cracked. It happened to mine because I did not make sure the wand and hose was drained before winter came. The water left in the wand expanded and cracked the trigger housing. The problem is that the trigger piece is easily replaceable, but it is not available. Alltrade makes you buy the complete wand.
May 12, 2011 | Garden
Water leaks out of the detergent tray like it's overflowing.
That happened to us when there was a piece of clothing (in this case a sock) that somehow left the drum and got lodged in the tube that feeds water into the drum. The entering water pours into and through the detergent tray, so when the tube feeding the drum is blocked, you get water pouring out of the detergent tray.
We had a repairperson come out to fix it, and he disassembled the whole thing enough that he could get at that tube and dislodge the sock. The next time it happened, I did the same thing, and managed to get it cleared as well. If you're not comfortable taking apart big chunks of your washer, it's probably smarter to let a qualified repairperson do this repair.
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a single handle Moen kitchen faucet with the built in sprayer in the faucet. No hot water will come out and no water pressure in the hot position. Any ideas?
Check the cutoff valve under the sink to be sure it's fully on. If it is then the cartridge in the faucet may need to be cleaned or replaced.
May 24, 2010 | Moen 7437 Chateau Single Hole Kitchen...
My water in the kitchen has a problem. When I turn the hot water on, the water pressure is very low and a load noise starts after a minute or less and the water starts to slow down. The dishwasher runs ok...
change the water inlet hose screens as they are plugged,also put the hoses on a hot water line and run hor water thru them and see what comes out of them in the sink,then replace the washer inlet hose screen
Mar 14, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Single handle Delta Kitchen Faucet
The red/blue cover just hides the screw that allows you to remove the handle.
Turn off the water :-)
Remove the handle, you will see that part of the faucet is a large half moon nut. sometimes you can loosen these with your hands, but most times you will need a tool. To avoid damaging the finish with the tool, use smooth jaw tools or protect the nut with a thin piece of rubber/cardboard etc between the jaws of the tool and the nut.
You can then remove the ball/stem, the washers and springs.
Replace the stem, washers and springs and reassemble just as you took it apart.
Be carefull that the little "nipple" lines up with the notches properly.
Take care that you know exactly how it came apart and which direction each prt was facing.
Nov 27, 2008 | Delta Commercial 400-WFELHHDF HDF Series...
McCulloch FH160G Pressure Washer Logo
145 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
