Question about GE Refrigerators
GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW VEG. BINS, HEAVY CONDENSATION ON WALLS OF REFRIG. CANT FIND A DRAIN HOLE AT BASE OF FREEZER OR FRIG.
  • GE Master
  • 1,606 Answers
Remove the food from the freezer . Remove the rear freezer panel , inside the freezer . At the base in the rear , use a hair dryer and defrost (you'll see a drain hole possibly in the middle of the drain ) . Defrost drain hole until hot water can be poured and go thru the hole . I use a small hose to blow thru the drain hole to remove any debris which could have accumulated inside the drain line .
Posted on Aug 02, 2009
I have water collecting in veg bins?
due to condensation due to either bad door seals or pluged drain evaporator line or hole
Aug 13, 2014 | Samsung RF217 Stainless Platinum 20 Cu....
Water is pooling under the veg/fruit drawers..cant tell where its from. Freezer temp is uneffected, temp appears fine, no condensation anywhere on refrig or contents...The first I noticed it was a week...
Your freezer goes through a defrost cycle and drains the melted ice ,somewhere the drain is clogged or iced up .Look for a little hole or hose coming into drain pan underneath and trace up.Might have to take back off.
Feb 17, 2011 | GE J Series 20.6 cu. ft. Top Freezer...
Water collects under the veg tray on bottom of fridge
Good day,
That's a classic example of the drain system either plugged up or iced up.
Remove the rear panel in the freezer, and inspect the drain hole where the condensed water drains out of the machine. Must be blown out or de-iced. Service techs use compressed air tank with hose to blow out the dirt. You'll need to improvise. However...
There are a few models that let the condensed water run down the back wall of the fridge, under the crisper drawers and then out a drain plug.
Check for this first.
Nov 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
We have a refrigerator model ET18NKXFW03 that drips water from the ceiling of the frig. We put a pan to collect the water but several times a week a stream of water leaks as well. It seems to happen more...
You will need to remove the food from the freezer and remove the ice maker if so equipped . Remove the 2 screws from the bottom freezer panel ( you will probably see a layer of ice here ) , and the 2 screws holding the inside rear freezer panel . Using a hair dryer , start in the center , below the coils , defrosting , until you see a drain hole . You want to defrost this hole ( hot water helps ) until water starts to flow down . Use a small hose inserted into the drain hole and blow thru it , to remove any unseen debris , built up inside the drain line . Reassemble the freezer .
Oct 11, 2009 | Whirlpool Refrigerators
Water is leaking in the freezer underneath the vegetable bin. Anybody knows what the problem maybe and how to fix it?- GE MAKE 685 ENERGYSTAR
I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 22, 2009 | GE Profile¿ Energy Star® 25.5...
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Ice acculumates in the bottom of freezer
Defrost drain tube is plugged. Drain is a round hole about the size of a quarter below the evaporator coils. (behind back wall of freezer.) Take a turkey baster with hot (not boiling) water and shoot it into the drain hole until water runs through it (into drain pan under refrig.)
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water accumulates under vegetable bins and spills out the front
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
Jul 06, 2008 | Whirlpool EL7ATRR Refrigerator
Defroster leaks
is the drain hole at the inside/back of the fridge blocked? check that you do not push foodstuffs too far back against the wall, and is there excess condensation from veg etc?
May 29, 2007 | GE PTS22SCRBS Top Freezer Refrigerator...
Refrigerators Logo
372 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
