Question about GE Washing Machines
Tub wont spin - GE Washing Machines
  • 41 Answers
Hi, check there is no water left inside drum 1st, if there is see if outlet pipe is blocked, if not could be faulty pump. if no water inside it could be motor brushes (carbons)
Posted on Aug 02, 2009
My washer wont leave sensing mode maytag bravos x model # mvwx500xw1
Shift mode sensor Orange thing at bottom of washer stuck on spin not shifting for agitation common in Whirlpool & Maytag and few others
Jul 04, 2016 | Maytag Washing Machines
Tub during the spin
It sounds like it may be a worn drum bearing. A loose transmission bolt could also cause the problem.
Dec 15, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer wont spin code e57
High current issue - 1. Remove the belt from the motor and spin the motor pulley. Does the motor spin free? No, replace the motor. Yes, go to step (3). 2. Spin the tub pulley. Does the tub spin free? No, check the tub bearings. Yes, go to step (3). 3. Disconnect the plug from the motor and measure the resistance of the windings (pin 1 to 2, pin 1 to 3, pin 2 to 3). All readings should be between 4 and 6 ohms. If readings are correct, replace the Speed Control Board. If readings are incorrect, replace the motor.
Aug 19, 2012 | Frigidaire Affinity ATF7000E Front Load...
Tub wont spin agitator works fine but on spin cycle tub will not spin
The brake mechanism is not releasing, you need to check for anything obviously damaged and check solenoid supply voltage.
Mar 10, 2012 | Whirlpool WTW5100SQ
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Washing machine tub is jamed and wont spin, motor is still spinning and belt is squeeling.
Sounds like either the brake or the transmission is locked up. Either way it is a major teardown.
Jan 03, 2010 | Westinghouse Washing Machines
My hec washing machine is not spinning and the water wont empty
Try turning the spin basket, something may have jammed itself inside the tub. You can remove the front kick panel and remove the tub to pump hose to clean it out.
If ok, you might have other problems like a broken belt in the back.
Sep 25, 2009 | Washing Machines
Kenmore Tumble Action Washer won't go to spin cycle
im a repairman,lets reason this out.if washer wont spin because the tub is so warped that when it spins its so out of balance then ok new tub.or the tub welds are broken and some part is dragging and not letting it spin then ok new tub.or spin bearing has failed and ruined tub support shaft,ok new tub.but why else would you need a new tub for a no spin problem,not sure,and to answer your other question , can you fix the tub if any of the above problem exist.no you would have to replace tub.i hope that helps,God bless ,tom....ps if i have been helpful please remember to help me with my ratings,tom
Jan 06, 2009 | Kenmore 43142 Front Load Washer
Washer wont spin
It is probably either the transmission or the motor. If the motor does not spin when the tub is trying to spin, then it is likely the high-speed windings on the motor. If the motor spins, but the tub doesn't, it is probable the transmission.
Sep 06, 2008 | KitchenAid Washing Machines
Wont spin
Could be the clutch. Is there a burning smell from the tub area? The clutch is directly under the tub. It's a royal pain to get out.
Apr 13, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
44 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
