Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven won't work
I have a GE XL44, about 7 years old. Last week, I was getting a glow in oven and smelling gas. Then no glow, no gas smell. Could this still just be an igniter problem?
  • GE Master
  • 3,361 Answers
Yes. The ignitor must register 2.9 amps or more to operate correctly and ignite the gas. Replace the ignitor.
Posted on Aug 02, 2009
Oven has worked on and off for the last year, now doesent work at all, i have the igniter exposed and it is glowing red, you do not smell gas at first but after about 2-3 min you begin to smell the gas,...
If your unit has a separate gas valve for the oven burner, that would be my first guess. But I would also check to make sure that the thermocoupler was not corroded, coated or defective.
Jul 15, 2011 | Ovens
No gas flow to oven, glow bar ignites no flame no smell of gas. safety gas safety valve was replaced
With the glow bar going and no gas smell that means you have a good circuit from control to valve and glow bar. For that glow bar to work it must change in resistance. If it is weak it won't change enough resistance to make the gas valve bi-metal open. Also the gas safety valve does not come preset and usually is bottomed out all the way for propane. You must adjust the orifice to aprox the same height as the old one to get the propah gas output for natural gas.
if your old valve did not leak and has continuity between the terminals it is fine. The ignitor/glowbar is weak. If it is dim orange that is usually a way to tell. Bumping the stove makes the bi-metal come on also is a sign of a weak glowbar
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 14, 2011 | Magic Chef Ovens
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Feb 20, 2009 | Kitchen Ranges
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
GE Spectra XL 44 Gas Oven Bottom Heating
you will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
Apr 28, 2008 | Kitchen Ranges
8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Feb 20, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
643 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
