Question about GE Spacemaker JVM1640SJ Microwave Oven
I have the exact same problem. It just happened.
The circuit breaker is fine yet there is no indication of power going into the unit. The unit was installed 10 years ago, almost to the day.
    Problem Solver:
  • 9 Answers
Thermo sensensor in top of unit? small round disc,hard to see sometimes from inside. easy fix for doit urself,too expensive to shop. $15 part w/shipping,45 min to remove,replace and clean the unit
Posted on Aug 02, 2009
  • 2 more comments
  • oldecarguye Aug 02, 2009
    thermo sensensor in top of unit? small round disc,hard to see sometimes from inside. easy fix for doit urself,too expensive to shop. $15 part w/shipping,45 min to remove,replace and clean the unit
FMV156DCA turns on, cook indicator lights but not cooking, timer counts down fine too
Hello epinvegas - Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then it sounds like the microwave has a faulty magnetron, wiring failure or control board. Contact a professional to assist with the repairs.
Feb 07, 2013 | Frigidaire FMV156DC Microwave Oven
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
Yesterday the microwave was working fine, this morning nothing at all...No power at all. I have checked the circuit breaker and everything is fine. The oven below it is on the same breaker and it works...
it sounds like the internal fuse has blown. if your handy, it can be done , however,,MAKE SURETO
DISCONNECT THE POWER SOURCE BEFORE BEGINNING. if your not 100% comfortable
have a trained technition service the unit...
Nov 20, 2010 | Whirlpool GH7208XR Convection / Microwave...
Blowing main breaker
I have a hard time believing that the home's main breaker is tripping instead of the branch circuit breaker that feeds the microwave. I suspect it is really just a difference in terms. You should disconnect it and try using in another outlet - preferably one on a different circuit if possible. If the breaker continues to trip; this appliance should be disconnected and either be discarded, repaired or replaced before using again.
If the microwave works as expected (on a different circuit), it may indicate the original circuit is overloaded. Microwave overs are supposed to be installed on a dedicated circuit. This means only one outlet is on the circuit - no other loads (lights, appliances, etc.) are permitted on this circuit. A microwave typically requires 10 Amps or more when on "high" and will require a significant portion of the power supplied by a 15 or 20 amp circuit breaker. There is little unused to power much of anything else. If other appliances go out when the microwave trips the circuit breaker, you should contact an electrician to have a dedicated outlet installed for the microwave.
I hope this helps!
Sep 23, 2010 | Maytag Microwave Ovens
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Apr 21, 2009 | Kenmore 62622 Microwave Oven
We have a JVM1870SF02 Microwave Oven. Everything
Is it on a gfci plug? If it is reset that. If not I would recheck the circuit breaker again
Sep 23, 2017 | GE Microwave Ovens
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
286 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
