Question about Haier HWR10XC3 Air Conditioner
If the fan and compressor are both running and no cold air
F the fan and compressor are both running and no cold air
    President:
  • 1,922 Answers
Are you sure the compressor is operating,can you hear it cycling over the noise of the fan???if its not its probably got one of 2 things wrong,rapid cycling or no comp operation: low refrigerant, no start condition: capacitor or contactor
Posted on Aug 02, 2009
No cold air
fan is likely gone. You can hook up a standard portable fan until you can get and install the replacement fan. Just MAKE SURE you've cut off the power (presumably this is a fridge) while you're wiring in the new part - then and only then- turn on the power. If that fails, check your connections. Still fails, you have a different problem.
Jul 15, 2017 | Heating & Cooling
Samsung fridge SR-L628EV, compressor works, all fans works but no cold air at all, it has been setting for two years but now is not giving cold air, any idea on how to fix it? Thank you
either needs freon [compressor will come on if low freon ] interior fan ,compressor internal valve damage tx valve damage condenser fan -etc can be anything with compressor running feel and look at condenser coils they should be hot and be careful of fan if not hot more than likely need freon
Sep 04, 2016 | Refrigerators
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Why is it blowing warm air?
U say the compressor fan is running. How about the compressor - is that running? Without the latter running there is no way you will ever get cold air!
Check for bad start cap/start relay.
Sep 21, 2015 | Heating & Cooling
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
CK301A I was able to spin my fan manually, but unit is not blowing cold air. I checked capacitor and it looked swollen. Going to have that replaced. After getting unit fan started, I let the unit run for...
Verify the compressor is running. If it is then you need to get the refrigerant charge checked. If it isn't, check for an overload that may need to be reset and use an ohmmeter to check the compressor motor winding. The fan and compressor run off of the same contactor so I would think it has power to it. Does the fan and the compressor use the same capacitor? If they do and you haven't replaced it yet then try that first.
Jul 17, 2010 | Goodman CKL24AR24 Air Conditioner
The ac is a window unit its blowing air out strongly but the air coming out is not cold
Make sure the condenser fan is running. That is the one that blows hot air outside. Also see if you can tell if the compressor is running. There is a discharge line and a suction line on the compressor. The suction line should feel cold and the discharge line will be very hot. If the condenser fan and compressor are both running then you may need to get the refrigerant charge checked.
Jun 04, 2010 | Kenmore Heating & Cooling
The lights are on in the refrigerator and freezer, but neither unit is cold. The thermometer on the refrigerator registers 55 degrees. Why is it not cooling??
First, make sure the compressor is running. It is underneath the refrigerator body. If the compressor is running, and you still don't have cold air, check the compressor fan. This should be close to the compressor. This fan draws air across the coils and removes heat from them. The compressor and fan must both be operating properly to get cold air.
Oct 18, 2009 | Refrigerators
FAN IS WORKIN BUT NOT COLD AIR
If the fan is running then it sounds like the compressor isn't turning on and the compressor is what makes the cold air,likely it's the thermostat because the thermostat tells the compressor to turn on.Try replacing the t-stat and it should be fine.
Aug 25, 2009 | Heating & Cooling
NO COLD AIR
If the fan and compressor are both running and no cold air then you’re low on refrigerant,
Thermostatic expansion valve closed or bad , dirty condenser or the valves are bad in the
compressor.
Apr 25, 2009 | Haier HWR10XC3 Air Conditioner
Haier HWR10XC3 Air Conditioner Logo
112 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
