Question about Cobra microTALKPR 190-2 Two Way Radio
How do i charge the cobra microtalk walk talkies? I have had them plugged in for days and they dont seem to charge at all
  • 3,051 Answers
Hello there
first i would check the charger to make sure that it is operating properly
next i would check the batteries i know that they are rechargeable but these batteries have a life time too and they will eventually die so you may want to get new batteries. make sure that they are what the manufacture recommends ok
best regards mike
Posted on Aug 04, 2009
MY COBRA MICRO TALK BATTERIES WILL NOT CHARGE HOW DO I KNOW IF THEY ARE CHARGED?
if you have a volt ohm meter see if theres voltage at the power adapter plug or the battery itself
Aug 09, 2014 | Cobra MicroTalk CXT145 Walkie Talkie...
Cxt90 microtalk radio charging
When charging batteries always do so with the radio switched off, this is a MUST, if you want to prolong your battery life, too many queries on this subject have resulted in burnt out batteries, being recharged with the radio on. This is a very big NO, NO....
I hope I have answered your query for you.
Cheers,
Peter
Feb 11, 2013 | Cobra Microtalk 100 FRS Walkie Talkie...
I have the cobra micro talk with rechargeable batteries my workers plug them up every night and get them in the morning but some arestill saying low battery, does the walkie talkie need to be turned off...
they charge better if they are turned off. since they do not have a paid dedicated channel, signals can
still be received by any walkie talkie using the same channel, and can deplete the charging process
to the radio. good luck!
Dec 07, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
We have lost manual for cobra microtalk walkie talkie & don't know how to turn on or use.
I couldn't locate your specific model, but all of the Microtalk series radios seem to be basically the same as far as operations. Follow the link below to a manual that you can download/print -- it should work fine with your radios:
http://www.cobra.com/downloads/manuals/PR4000WX_manual.pdf
Bill B
Apr 18, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
I too need a charger for the Cobra microtalk Walkie Talkie
u can use a phone charger as long as the jack is the same as your jack, walmart has about any kind they make.
Jul 09, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Microtalks don't seem to charge, even charged many hours
When you say they worked fine for a long time, do you mean a long time as in "hours", or for many months or years? If hours, then remove the batteries and be sure they are in correctly and plug the charger into a different electrical outlet. If the radios have not been used for many months or longer, you probably need to replace the rechargeable battery.
Feb 06, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Microtalks won't charge
I have the Cobra Microtalk 4100 FRS radios with charging base. After changing the batteries with new nimh rechargables the charge light would not illuminate and the unit would not charge. I noticed the original batteries had a metal band around one end. This band makes a small connection inside the battery compartment on the first battery. Seems to be a cheap way to ensure you dont try to recharge the unit with non-rechargable batteries installed. I rapped a small piece of tinfoil around one end of the first battery in the new set then popped it back in and now they will charge correctly again. Dont try this with non-rechargable batteries! I would recomend buying original replacement batteries.
Nov 28, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
Cobra microTALKPR 190-2  Two Way Radio Logo
1,228 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
