SOURCE: Hi, my1999 mercury mystique sunroof will
If the fuse is bad you won't hear the actuator buzzing. Sounds like something has stripped or broke.
SOURCE: 1995 Lincoln Continental, passenger seat won't tilt back forward
YOU HAVE A SWITCH OR A TILT ACTUATOR MOTOR PROBLEM. LINCOLNS HAVE 5 OR 6 ELECTRIC MOTORS MOUNTED ON THE UNDERSIDE OF EACH FRONT SEAT WHICH REQUIRES REMOVING THE SEAT TO INSPECT .THEIR ARE ALSO CABLES ATTATCHED TO THESE MOTORS SO LISTEN WHEN YOU HIT THE TILT SWITCH DO YOU HEAR A MOTOR NOISE? IF YOU DO THEN YOU MAY HAVE A BAD CABLE.
