Question about Creative Labs Inspire Digital 5500 Computer Speakers
Edifier m1250 speakers no sound - Creative Labs Inspire Digital 5500 Computer Speakers
No sound playing from either speaker on the Edifier Multimedia Speaker M3300 setup.
Go to http://www.edifier.ca/french/speakers/m3300/m3300-EN-FR-manual.pdf and check the troubleshooting guide. I notice it says to check to make sure the mute button on the remote is off. Try it without the remote plugged in, also. Try hooking up another device with a headphone jack like an mp3 player. The only other thingI can think of would be a blown fuse, which sometimes lets a small signal through with some amps, but I don't see any fuse holder.
Dec 09, 2014 | Edifier Audio Players & Recorders
Sound driver edifier m1250
Go to your systems Device Driver section in the Control Panel section. Go tot eh Sound area and highlight the line that indicates the installed driver. Click on the option UPDATE. See if the update fixes the problem.
Jan 15, 2014 | Audio Players & Recorders
Edifier m1350
As long as the woofer is functional, get a pair of 8 Ohm matching speakers from Radio Shack.
Jan 09, 2014 | Edifier Audio Players & Recorders
I don't sound from my left Edifier M1250 speaker
If possible, swap the speakers side for side. If that same speaker does not work on the opposite side, the speaker is likely defective. However, the connection to your computer could be bad, causing one channel to drop out.
Dec 29, 2013 | Edifier M1250 2.0 Multimedia Speaker...
Edifier C2 amplifier repair
My Edifier HCS2330 Amplifier stopped working and now the system is useless. Any recommendations on where to get it fixed from? Or any place i can buy the amp separately? or maybe even any other brand amp i can buy for cheap price?
Jul 14, 2013 | Car Audio & Video
We fixed speakers to my tv but so sound is heard
look first to see if a dvd etc connected to a rear input gives sound.
Nov 05, 2012 | Edifier M1380 2.1 Multimedia Speaker...
I fixed the speakers to my Led tv but no sound can be heard
Nov 05, 2012 | Edifier M1380 Multimedia 2.1 Speaker Two...
No device connected
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps you
Feb 12, 2011 | Klipsch Edifier M1250 2 Speakers
Creative Labs Inspire Digital 5500 Computer Speakers Logo
503 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
