Question about Honeywell Programmable Thermostat Heater
Ihave to many wires for the thermostat i bought
I have to many wires for the thermostat i bought
  • t1m130
    t1m130 May 11, 2010
    where did the wires hook up on the old one and what terminals do you have onthe new one?
  • 29 Answers
Buy another t-stat with heat and cool options
Posted on Aug 03, 2009
No fan when ac kicks on Ihave a eb15b funace with a coleman ac
The heat will normally use a low speed on the fan, & the AC along with the fan switch on the thermostat will use the high speed. The thermostat turns that high speed on when there is a call for cooling & is the same switch if you were to manually turn the fan from auto to on. Try turning the fan on @ the thermostat. If it works, then replace your thermostat. If it doesn't, it could be a bad fan speed, a bad fan relay on a control board or external relay, or a loose or broken green thermostat wire.
Apr 14, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
My central heating is not working. ihave honey well mercury 20v thermostat
You can easily check the thermostat by jumping across the R & W terminals. If the furnace fires your problem is the thermostat. If not, the issue is with the furnace or the wire between the thermostat and furnace. I can walk you thruogh a dignostic check but you will at least need a volt meter.
Mar 05, 2013 | Heating & Cooling
Ihave a Westinghouse BJ434V-R and the bottom freezer is working perfectly, but the top fridge just stopped cooling, is this a thermostat problem if so howis it replaced, Alan
Is the fridge part a separate system? More likely a fan stopped blowing cold air through from the freezer section. If Separate, Thermostat knob prises off end and you will see where wires and sensing phial are located.
May 19, 2012 | Westinghouse Refrigerators
I have to push the reset button because the unit gets to hot. Ihave set on the lowes setting. What is the problem?
It sounds like a bad thermostat. Replace them both from Lowe's, H/D, etc. Cost will be ~$30. Note that even though the package may not say Rheem on it, it is a universal replacement part. I have used them several times with no problems.
Isolate the power to the heater by turning the breaker OFF. If your unit is equipped with a service disconnect, switch it off as well.
It's a good idea to make a sketch of each thermostat, noting the wire color and the direction that it takes (for example, 2nd terminal, right side, blue wire, heads down).
Replace each thermostat and wire it up. Make sure that all connections are tight. Set the desired temperature. Replace the insulation and the cover plates.
Best regards, --W/D--
Jan 24, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Goodman airhandler model #A24-10, serial #9305071035 and can not get fan motor to cut off except by turning off breaker. Ihave replaced two sequencers and checked out all 24volt wires to...
https://www.wedclix.com/wp-content/uploads/2017/12/aept-aepf-thermostat-control-wiring-central-air-and-heat-diagram.jpg
Let me know if this is the diagram u looking at?
Jan 05, 2018 | Goodman Heating & Cooling
Storing channels and time display
* Connect Yellow wire to continues power ( it is back-up power to memory circuit)
* Connect Red wire to switched power
You can download User Manual and Installation Guide for CDX-S2000 from Sony Support for more information.
Oct 23, 2008 | Sony CDX-S2000 CD Player
2004 jeep liberty thermostat change?
ihave to change my thermostat in my 04 jeep liberty is it hard
Oct 06, 2008 | 2004 Jeep Liberty
Honeywell RTH230B
Jumper RH to RC and Y to W (Just like the old thermostat) and hook the cable wires as you have indicated with the exception of the blue wire - clip it back - it is not needed. This is a heat pump system so heating and cooling are done by the same unit. RH stands for Red Heat, RC for Red Cool, the W and Y are the neutral sides to the heat and cool control circuit. That should get you going good enough to start learning the intricacies of programming the box.
Jun 02, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
124 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
